[mapserver-users] OGR Geojson error
Weisbender, Eric
Weisbend at WAPA.GOV
Tue Sep 29 10:27:09 PDT 2020
Thanks Kobben. I think it might be more than a file naming issue. Below is the response from ogrinfo but I can find anything related online. Any ideas?
/usr/local/bin/ogrinfo http://opendata.arcgis.com/datasets/5da472c6d27b4b67970acc7b5044c862_0.geojson
ERROR 1: Peer's certificate has an invalid signature.
FAILURE:
Unable to open datasource `http://opendata.arcgis.com/datasets/5da472c6d27b4b67970acc7b5044c862_0.geojson' with the following drivers.
-> PCIDSK
-> PDF
-> EEDA
-> ESRI Shapefile
-> MapInfo File
-> UK .NTF
-> OGR_SDTS
-> S57
-> DGN
-> OGR_VRT
-> REC
-> Memory
-> BNA
-> CSV
-> GML
-> GPX
-> KML
-> GeoJSON
-> GeoJSONSeq
-> ESRIJSON
-> TopoJSON
-> OGR_GMT
-> WAsP
-> OpenFileGDB
-> XPlane
-> DXF
-> CAD
-> Geoconcept
-> GeoRSS
-> GPSTrackMaker
-> PGDUMP
-> GPSBabel
-> SUA
-> OpenAir
-> OGR_PDS
-> WFS
-> WFS3
-> HTF
-> AeronavFAA
-> EDIGEO
-> GFT
-> SVG
-> CouchDB
-> Cloudant
-> Idrisi
-> ARCGEN
-> SEGUKOOA
-> SEGY
-> ODS
-> XLSX
-> ElasticSearch
-> Carto
-> AmigoCloud
-> SXF
-> Selafin
-> JML
-> PLSCENES
-> CSW
-> VDV
-> MVT
-> TIGER
-> AVCBin
-> AVCE00
-> NGW
-> HTTP
Eric Weisbender | GIS Program Lead
Western Area Power Administration | Headquarters
(O) 720.962.7280 | weisbend at wapa.gov<mailto:weisbend at wapa.gov>
From: b.j.kobben at utwente.nl <b.j.kobben at utwente.nl>
Sent: Saturday, September 26, 2020 2:53 AM
To: Weisbender, Eric <Weisbend at WAPA.GOV>; mapserver-users at lists.osgeo.org
Subject: [EXTERNAL] Re: [mapserver-users] OGR Geojson error
It might be simply that file names beginning with a number are always a bad idea, because several libs and systems out there have problems with it...?
Barend Köbben
On 25/09/2020, 16:45, "mapserver-users on behalf of Weisbender, Eric" <mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org> on behalf of Weisbend at WAPA.GOV<mailto:Weisbend at WAPA.GOV>> wrote:
Hello List,
I have two sources of geojson data in my map file. One works fine the other does not. The one that works streams into the browser when I go to it directly. The other source downloads a file. The one that does not work I get the following MapServer error. Also the geojson sources are listed below. The layer defs are the same in the mapfile.
Thanks in advance for your help.
Error:
msOGRFileOpen(): OGR error. Open failed for OGR connection in layer `fire_nifc_point . File not found or unsupported format. Check server logs.
Works: http://earthquake.usgs.gov/earthquakes/feed/v1.0/summary/all_day.geojson<https://gcc02.safelinks.protection.outlook.com/?url=http%3A%2F%2Fearthquake.usgs.gov%2Fearthquakes%2Ffeed%2Fv1.0%2Fsummary%2Fall_day.geojson&data=02%7C01%7C%7C0f22378af4d145891f5908d861f986da%7C31ae220fb94f463a9cfd15bbc9909df5%7C0%7C0%7C637367072099492666&sdata=aKFT%2B1hURzGSVSfk1h44nPYGwlxdE4QDPkKHeXhiHIk%3D&reserved=0>
No Worky: http://opendata.arcgis.com/datasets/68637d248eb24d0d853342cba02d4af7_0.geojson<https://gcc02.safelinks.protection.outlook.com/?url=http%3A%2F%2Fopendata.arcgis.com%2Fdatasets%2F68637d248eb24d0d853342cba02d4af7_0.geojson&data=02%7C01%7C%7C0f22378af4d145891f5908d861f986da%7C31ae220fb94f463a9cfd15bbc9909df5%7C0%7C0%7C637367072099492666&sdata=j%2FlTPVAqXWFCsfAaQqsIKKH%2FE3o4jup0M%2FMQUxbMoNI%3D&reserved=0>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20200929/703a0054/attachment-0001.html>
