[mapserver-users] svg symbols, svg output, anchorpoints
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Feb 10 09:14:40 PST 2021
Hi Iljya,
Would you mind also updating your tests to run against the latest
release (MapServer 7.6.2). thanks,
-jeff
Jeff McKenna
GatewayGeo: MapServer Consulting and Training Services
co-founder of FOSS4G
http://gatewaygeo.com/
On 2021-02-10 12:59 p.m., Iljya Kalai wrote:
> Hi,
> I'm running into some fascinating behaviour with svg symbols and svg
> output. I'm new to svg so this may very well be expected behaviour, but
> I cannot figure out what is going on.
> The symbols are not being anchored properly at the anchorpoint when the
> output is SVG, but everything works as expected when the output is PNG.
> A minimal example with all the necessary resources to reproduce this is
> here:
> https://gist.github.com/iljya/e67a2a245c6968e685c11498a8361fe0
> <https://gist.github.com/iljya/e67a2a245c6968e685c11498a8361fe0>
> It is possible that this is related to these issues, but I'm not sure:
> https://github.com/mapserver/mapserver/issues/5593
> <https://github.com/mapserver/mapserver/issues/5593>
> https://trac.osgeo.org/mapserver/ticket/4184
> <https://trac.osgeo.org/mapserver/ticket/4184>
> Thanks for your help, even if it is just a confirmation that others are
> actively using the SVG renderer.
> Kind regards,
> Iljya
> MapServer version 7.4.3 OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ
> SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=SVG_SYMBOLS
> SUPPORTS=RSVG SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
> SUPPORTS=THREADS SUPPORTS=GEOS SUPPORTS=PBF INPUT=JPEG INPUT=POSTGIS
> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
