[mapserver-users] WMS Time layer from geojson
Jesper Kempe
jesper.kempe at gmail.com
Thu Feb 11 00:40:47 PST 2021
Hi
I am trying to get WMS time to work for a vector layer from GeoJSON-data.
The data has a property start that is a DateTime that I want to filter the
items in the geojson based on TIME in the WMS query.
Ogrinfo shows:
OGRFeature(debug_wmstime):0
level (String) = high
start (DateTime) = 2021/02/09 14:00:00+00
POLYGON ((10.87646484375 61.7627288304727,10.9423828125
60.0758034247597,17.73193359375 60.1633760564878,17.7978515625
61.7835133871372,10.87646484375 61.7627288304727))
But no matter how I configure the mapfile I can´t get it to work.
As soon as I add
"wms_timeitem" "start"
to Layer METADATA the image goes blank.
And the debug logfile gives no errors.
I can get ogrinfo to filter the data in the geojson with:
ogrinfo -where "start='2021-02-09T14:00:00Z'" debug_wmstime.geojson
debug_wmstime
But not get Mapserver to work with TIME=2021-02-09T14:00:00Z in a
WMS-request.
Attached is the geojson file and a simple mapfile I have used for testing.
A wms query like this is what I am testing:
/debug_wmstime.map?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&FORMAT=image/png&TRANSPARENT=true&STYLES&LAYERS=time_debug&SRS=EPSG%3A4326&WIDTH=200&HEIGHT=464&BBOX=10,47,18,62&TIME=2021-02-09T14:00:00Z
The expected result is to to only see a yellow square at the top of the
image. The other features in the geojson should not be visible with this
TIME.
Does anyone have a clue what I might be doing wrong?
Cause it should be possible to do this right?
Any help is appreciated!
Jesper
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210211/556edc67/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210211/556edc67/attachment.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210211/556edc67/attachment-0001.obj>
