[mapserver-users] mapserver 7.6.2
Stephane Poissant
spoissantca at gmail.com
Mon Jan 4 10:58:04 PST 2021
I have tried many things but cannot get to compile ma-server successfully.
I rely on repository yum packages for everything but for geos (which I build manually).
My Makefile (relevant part)
CMAKEFLAGS= -DWITH_GEOS=1 \
-DCMAKE_SHARED_LINKER_FLAGS="-lgcov" -DWITH_CLIENT_WMS=1 \
-DWITH_CLIENT_WFS=1 -DWITH_KML=1 -DWITH_SOS=1 -DWITH_CSHARP=1 -DWITH_PHP=0 -DWITH_PERL=1 \
-DWITH_PYTHON=0 -DWITH_JAVA=1 -DWITH_THREAD_SAFETY=1 -DWITH_FRIBIDI=1 -DWITH_FCGI=0 -DWITH_EXEMPI=0 \
-DCMAKE_BUILD_TYPE=Release -DWITH_RSVG=0 -DWITH_CURL=1 -DWITH_HARFBUZZ=1 -DWITH_POINT_Z_M=1 -DWITH_MSSQL2008=OFF \
-DCMAKE_PREFIX_PATH="/usr/proj72/;/usr/pgsql-12;/usr/gdal32/;/usr/lib64/“
Packages installed from repo:
- name: install postgresql pieces
yum: pkg={{item}} state=latest
with_items:
- postgresql12
- postgresql12-devel
- postgresql12-libs
- proj72
- proj72-devel
- postgis30_12
- postgis30_12-devel
- mpfr
- mpfr-devel
- gmp
- gmp-devel
- gdal32
- gdal32-devel
- gdal32-libs
Whenever I launch the build process, I get a boost error:
[ 82%] Building C object CMakeFiles/shptreetst.dir/shptreetst.c.o
[ 82%] Linking C executable shptreetst
//usr/lib64/libSFCGAL.so.1: undefined reference to `boost::archive::text_oarchive_impl<boost::archive::text_oarchive>::save(std::string const&)'
//usr/lib64/libSFCGAL.so.1: undefined reference to `boost::archive::basic_binary_oprimitive<boost::archive::binary_oarchive, char, std::char_traits<char> >::save(std::string const&)'
//usr/lib64/libSFCGAL.so.1: undefined reference to `boost::archive::text_iarchive_impl<boost::archive::text_iarchive>::load(std::string&)'
collect2: error: ld returned 1 exit status
make[3]: *** [shptreetst] Error 1
make[3]: Leaving directory `/root/inst/mapserver-7.6.2/build'
make[2]: *** [CMakeFiles/shptreetst.dir/all] Error 2
make[2]: Leaving directory `/root/inst/mapserver-7.6.2/build'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/root/inst/mapserver-7.6.2/build'
make: *** [cmakebuild] Error 2
Any suggestions are welcomed!
SP
Stéphane Poissant
Portable: 514-793-3506
> On Dec 31, 2020, at 10:40 AM, Steve Lime <sdlime at gmail.com> wrote:
> The original error looks like it was related to this:
> https://stackoverflow.com/questions/39700537/undefined-reference-to-boost-serialization-functions <https://stackoverflow.com/questions/39700537/undefined-reference-to-boost-serialization-functions>
> I think you do something like this (see https://stackoverflow.com/questions/25243336/specifying-libraries-for-cmake-to-link-to-from-command-line <https://stackoverflow.com/questions/25243336/specifying-libraries-for-cmake-to-link-to-from-command-line>):
> cmake ... CMAKE_C_STANDARD_LIRBARIES="-lboost_serialization"
> The new error looks to be related to multiple versions of GDAL installed. If you search on "AH01215: GDAL: In GDALDestroy - unloading GDAL shared library" you'll see that error referenced in a couple of forums, including mapserver-users. Do you have both a package and source-built GDAL? You might be better off uninstalling the source-built stuff.
> --Steve
> On Wed, Dec 30, 2020 at 2:13 PM Jeff McKenna <jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>> wrote:
> Hi Stephane,
> I'm not sure about your last issue. You could first execute 'sudo
> ldconfig' so your last compiled libs are found, then try a shp2img
> command with your mapfile.
> I have seen cases where there are conflicting library versions used by
> either the GDAL or MapServer dependencies: test this with a 'ldd <lib
> name> command.
> That's not a fun scenario, but, I've been there before ha.
> Sorry maybe others have better advice for this.
> -jeff
> Jeff McKenna
> GatewayGeo: MapServer Consulting and Training Services
> co-founder of FOSS4G
> http://gatewaygeo.com/ <http://gatewaygeo.com/>
> On 2020-12-30 1:36 p.m., Stephane Poissant wrote:
> > HI Jeff,
> > That was a partial success! Thank you for you recommendation!
> > It compiled successfully by compiling gems and recompiling goal as you
> > suggested.
> > I still have 1 issue.
> > While rendering stuff that use to work on previous version, it no longer
> > works in this lates one.
> > I get AH01215 error in http.
> > AH01215: GDAL: In GDALDestroy - unloading GDAL shared library.:
> > /var/www/html/map/mapserv.cgi, referer: http://utility.sk.com/ <http://utility.sk.com/>
> > <http://utility.sk.com/ <http://utility.sk.com/>>
> > I am not a developper. It is hard for me to describe where this issue
> > can possibly come from.
> > It does not render on screen the way it should be.
> > I will turn back on perl, have ruby, python and php in the makefile as
> > it could be related….
> > Nevertheless, I would like to thank you for your very quick response and
> > "right on" target answers!
> > SP
> > Stéphane Poissant
> > spoissantca at gmail.com <mailto:spoissantca at gmail.com> <mailto:spoissantca at gmail.com <mailto:spoissantca at gmail.com>>
> >> On Dec 30, 2020, at 10:14 AM, Jeff McKenna
> >> <jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com> <mailto:jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>>>
> >> wrote:
> >> Also, after you compile GEOS be sure to recompile GDAL ('make clean'
> >> first), then continue on to tackle your MapServer cmake command.
> >> Happy new year to all,
> >> -jeff
> >> Jeff McKenna
> >> http://gatewaygeo.com/ <http://gatewaygeo.com/> <http://gatewaygeo.com/ <http://gatewaygeo.com/>>
> >> On 2020-12-30 9:56 a.m., Jeff McKenna wrote:
> >>> Hi Stephane,
> >>> Be sure to compile GEOS (3.9.0 is recommended from
> >>> http://download.osgeo.org/geos/geos-3.9.0.tar.bz2 <http://download.osgeo.org/geos/geos-3.9.0.tar.bz2> ), and then add
> >>> into your cmake command: -DWITH_GEOS=1
> >>> Wishing you a happy new year,
> >>> -jeff
> >> _______________________________________________
> >> mapserver-users mailing list
> >> mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
> >> https://lists.osgeo.org/mailman/listinfo/mapserver-users <https://lists.osgeo.org/mailman/listinfo/mapserver-users>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210104/68fa39b5/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210104/68fa39b5/attachment-0001.png>
