[mapserver-users] Mapserver 7.6.2
Eichner, Andreas - SID
Andreas.Eichner at sid.sachsen.de
Thu Jan 7 22:24:19 PST 2021
Hallo Stéphane,
glad to hear it works. The problem with this is how to keep those packags up to date. As long as this list is relatively static you might be able to use a script to synchronize them to a local directory, create the metadata and use this local repository with yum-priorities to favour those packages.
The messages in to Apache httpd-log don't log like errors. AFAIK those a just normal message. CGI doesn't define a way to categorize messages so debug, info, err are all going the to same stderr channel. The CGI-Module simply logs everything as class "error". It should be possible to redirect those MapServer messages to a separate file using mapfile-directives (see https://mapserver.org/optimization/debugging.html)
Regards, Andreas
-----Ursprüngliche Nachricht-----
Von: Stephane Poissant <spoissantca at gmail.com>
Gesendet: Donnerstag, 7. Januar 2021 20:40
An: mapServer-users <mapserver-users at lists.osgeo.org>
Cc: Jeff McKenna <jmckenna at gatewaygeomatics.com>; Eichner, Andreas - SID <Andreas.Eichner at sid.sachsen.de>
Betreff: Re: Mapserver 7.6.2
Good day Andreas,
Your suggestion about replacing boost packages from AWS with CentOS ones worked.
Good catch. I was able to finally compile and install all my requirements. Thumbs up!
I had to download the whole list and install using rpm -ivh *.rpm.
One more thing.
I am able to render many tiles (images) but I have trouble with some others. I double checked for librairies to avoid having duplicates or many versions...
But it does not seem to be the case.
I am getting a bunch of the following in my apache logs:
#### (Some data was replaced with xxxx on purpose for security reasons in the below log output) ###
[cgi:error] [pid 2512] [client 10.2.10.155:60456] AH01215: GDAL: GDALOpen(PG:host=xxxxxxxx.com <http://xxxxxxxx.com> port=xxxx dbname=‘xxxxxx' user=‘xxxxx' password=XXXXXXXXXXXXXXXXXXXXXX schema='public' table=‘xxxxxx' mode='2', this=0x125df80) succeeds as PostGISRaster.: /var/www/html/map/mapserv.cgi, referer: http://xxxxx.com/
[cgi:error] [pid 2509] [client 10.2.10.155:60451] AH01215: GDAL: GDAL_CACHEMAX = 388 MB: /var/www/html/map/mapserv.cgi, referer: http://xxxxx.com/
…//snip//...
AH01215: GDAL: In GDALDestroy - unloading GDAL shared library.
What could cause that? Flags while doing cmake? (Python maybe)
(I am using the below one):
cmake -Wno-dev -DCMAKE_PREFIX_PATH="/usr/proj72/;/usr/pgsql-12/;/usr/gdal32;/usr/geos39/" -DWITH_PYTHON=0 -DWITH_JAVA=1 -DWITH_THREAD_SAFETY=1 -DWITH_FRIBIDI=1 -DWITH_FCGI=0 -DWITH_EXEMPI=0 -DWITH_GIF=0 -DWITH_FCGI=0 -DWITH_PROTOBUFC=0 -DWITH_CLIENT_WMS=1 -DWITH_CLIENT_WFS=1 -DWITH_KML=1 -DWITH_SOS=1 -DCMAKE_BUILD_TYPE=Release ..
— Stéphane
