[mapserver-users] 7.6.3 released - includes important security fix
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Jun 3 13:33:05 PDT 2021
The associated CVE security ID for this is: CVE-2021-32062
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-32062
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
On 2021-04-30 7:55 p.m., Steve Lime wrote:
> The MapServer team is pleased (kinda) to announce the 7.6.3 security and
> maintenance release.
> Importantly, this release addresses a flaw, discovered by project
> developers, in MapServer CGI mapfile loading that makes it possible to
> bypass security controls (ticket #6313). This flaw makes it difficult to
> easily limit where MapServer can load a mapfile from and affects
> versions 4.10 and later. This is a critical issue and all users are
> encouraged to update as soon as possible.
> What does this mean for you?
> 1. If you've not used MS_MAP_PATTERN or MS_MAP_NO_PATH as part of
> securing your installation then this doesn't have much impact since
> you're not using the controls. That said, this is a critical
> configuration step and you should upgrade and make use of those
> controls to limit where mapfiles can be accessed.
> 2. If you've relied on MS_MAP_PATTERN exclusively, you should upgrade
> and be in good shape. However, it's a great time to review and test
> MS_MAP_PATTERN.
> 3. If you've relied on MS_MAP_NO_PATH primarily (like me), you should
> upgrade and set a value for MS_MAP_PATTERN.
> We are simultaneously releasing versions 7.0.8, 7.2.3 and 7.4.5 as well.
> Updates to binary distributions will follow ASAP.
> For the list of additional changes see the Changelog at
> https://mapserver.org/development/changelog/changelog-7-6.html
> <https://mapserver.org/development/changelog/changelog-7-6.html> Or head
> to Download at https://mapserver.org/download.html
> <https://mapserver.org/download.html> For those wanting searchable
> offline documentation, the updated PDF is available at
> https://download.osgeo.org/mapserver/docs/MapServer.pdf
> <https://download.osgeo.org/mapserver/docs/MapServer.pdf>
> -- The MapServer Team
