[mapserver-users] connect label to features
Luca Delucchi
lucadeluge at gmail.com
Thu Jun 24 14:57:37 PDT 2021
Hi Jeff,
On Thu, 24 Jun 2021 at 21:37, Jeff McKenna
<jmckenna at gatewaygeomatics.com> wrote:
> Luca, I've done more testing and in fact I can get point & line features
> (with label leader lines) to work with that mapfile. I can now see
> Thomas' point, that this is a documentation issue (likely when I
> originally documented this I could only get it to work with polygons,
> but now when I test I can get points,lines,polygons to work by adapting
> that same mapfile).
Thanks a lot, I tried again changing some parameters but I didn't get
any leader lines.
I'm using mapserver 7.6.2 provided by Debian
> I'll fix that document now.
> If you post your mapfile and data I can test your data locally here.
here you are an example not working for me, with my output png
> -jeff
ciao
Luca
www.lucadelu.org
Type: application/zip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210624/766e2aa4/attachment.zip>
