[mapserver-users] Fwd: MapServer PostGIS: WMS Layers Without Features
Steve Lime
sdlime at gmail.com
Tue Mar 2 07:06:11 PST 2021
What are you using to view the WMS service? What do you get if you take WMS
configuration out of the equation and just do a call like so:
http://localhost/cgi-bin/mapserv.exe?map=[your
mapfile]&mode=map&layers=all
That should get you an image with all the features in all the layers for
your default extent.
--Steve
On Mon, Mar 1, 2021 at 1:05 PM Nathan L <nathan.tyler.lowry at gmail.com>
wrote:
> ---------- Forwarded message --------- From: Nathan L
>>> nathan.tyler.lowry at gmail.com Date: Tue, Feb 23, 2021 at 1:04 PM
>>> Subject: MapServer PostGIS: WMS Layers Without Features To: GISCO ListServ
>>> List at giscolorado.org
>>> Hi, ya'll! I'm in need of some help.
>>> I've prepared an instance of PostGIS and MapServer on the same machine.
>>> I have loaded data into PostGIS and can view these features successfully in
>>> thick clients (ArcGIS Pro, QGIS).
>>> My MapServer appears to be creating a successful WMS service with two
>>> layers. However, these two layers, called from PostGIS, are empty of any
>>> features. The same two layers were the features successfully confirmed to
>>> be in the PostGIS database, above. Nevertheless, my WMS layers from
>>> MapServer show up empty.
>>> What am I missing?
>>> My Mapfile: https://pastebin.com/tRTJKTxA
>>> My ms_error.txt: https://pastebin.com/daJJMEkJ
>>> My PostgreSQL log file: https://pastebin.com/EN2LzheE
>>> My WMS Returns: https://pastebin.com/NR0W0Pg7
>>> Nathan Tyler Lowry
>>> Comprehensive GIS Solutions
>>> (719) 208-7092 Desk
>>> (719) 963-3571 Cell
>>> (719) 960-2084 Fax
>>> Nathan.Tyler.Lowry at gmail.com
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210302/b875f71d/attachment.htm>
More information about the MapServer-users
