[mapserver-users] Fwd: MapServer PostGIS: WMS Layers Without Features
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Tue Mar 2 07:25:54 PST 2021
First thing that comes into my mind is that for some reason Mapserver may believe that the request is outside the area where you have data. I would double check the projections and extents.
-Jukka Rahkonen-
Lähettäjä: mapserver-users <mapserver-users-bounces at lists.osgeo.org> Puolesta Steve Lime
Lähetetty: tiistai 2. maaliskuuta 2021 17.06
Vastaanottaja: Nathan L <nathan.tyler.lowry at gmail.com>
Kopio: Mapserver <mapserver-users at lists.osgeo.org>
Aihe: Re: [mapserver-users] Fwd: MapServer PostGIS: WMS Layers Without Features
What are you using to view the WMS service? What do you get if you take WMS configuration out of the equation and just do a call like so:
http://localhost/cgi-bin/mapserv.exe?map=[your<http://localhost/cgi-bin/mapserv.exe?map=%5byour> mapfile]&mode=map&layers=all
That should get you an image with all the features in all the layers for your default extent.
--Steve
On Mon, Mar 1, 2021 at 1:05 PM Nathan L <nathan.tyler.lowry at gmail.com<mailto:nathan.tyler.lowry at gmail.com>> wrote:
---------- Forwarded message --------- From: Nathan L nathan.tyler.lowry at gmail.com<mailto:nathan.tyler.lowry at gmail.com> Date: Tue, Feb 23, 2021 at 1:04 PM Subject: MapServer PostGIS: WMS Layers Without Features To: GISCO ListServ List at giscolorado.org<mailto:List at giscolorado.org>
Hi, ya'll! I'm in need of some help.
I've prepared an instance of PostGIS and MapServer on the same machine. I have loaded data into PostGIS and can view these features successfully in thick clients (ArcGIS Pro, QGIS).
My MapServer appears to be creating a successful WMS service with two layers. However, these two layers, called from PostGIS, are empty of any features. The same two layers were the features successfully confirmed to be in the PostGIS database, above. Nevertheless, my WMS layers from MapServer show up empty.
What am I missing?
My Mapfile: https://pastebin.com/tRTJKTxA
My ms_error.txt: https://pastebin.com/daJJMEkJ
My PostgreSQL log file: https://pastebin.com/EN2LzheE
My WMS Returns: https://pastebin.com/NR0W0Pg7
Nathan Tyler Lowry
Comprehensive GIS Solutions
(719) 208-7092 Desk
(719) 963-3571 Cell
(719) 960-2084 Fax
Nathan.Tyler.Lowry at gmail.com<mailto:Nathan.Tyler.Lowry at gmail.com>
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210302/d0d305e2/attachment.htm>
More information about the MapServer-users
