[mapserver-users] differing image size with different mapserver versions
Richard Greenwood
richard.greenwood at gmail.com
Mon May 17 06:49:30 PDT 2021
On Mon, May 17, 2021 at 7:05 AM Rahkonen Jukka (MML) <
jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Hi,
> Are you sure about “I actually found that 6.4 produced small, aliased
> images with both the GD and AGG drivers”.
Yes, I just tested again. In 6.4 I get identical (visually and size) images
with:
OUTPUTFORMAT
DRIVER "AGG/PNG" or "GD/PNG".
Interestingly, "GD/PNG" does not throw an error in mapserver 7.6 or main
(MapServer 7.7).
> Originally the AGG library could only do anti-aliasing and that affected
> also Mapserver 5
> https://lists.osgeo.org/pipermail/mapserver-users/2007-September/025467.html
> I guess that Mapnik folks have since that added support for controlling
> anti-aliasing with gamma setting http://mapnik.org/mapnik-reference/.
> I can see that gamma can be used also with Mapserver
> https://www.mapserver.org/mapfile/outputformat.html
> Have a try with gamma=0. However, Even wrote that turning off antialiasing
> is possible only in master, so perhaps gamma=0 does not work.
I tried
OUTPUTFORMAT
FORMATOPTION "GAMMA=0"
I see no difference in the output image in 7.7 (main) or 7.6 or 6.4. Is my
syntax correct?
> The documentation for Mapserver 5 tells that “All ANTIALIAS keywords are
> now ignored". But the keyword still appears in quite a many places:
> https://mapserver.org/search.html?q=antialias
> Would it be time to remove them as well as now not useful references to GD
> renderer (removed by RFC 99 in 2013)?
>From my testing it seems that <=6.4 is aliased and >=7.0 is antialiased
regardless of ANTIALIAS options.
> -Jukka Rahkonen-
> *Lähettäjä:* mapserver-users <mapserver-users-bounces at lists.osgeo.org> *Puolesta
> *Richard Greenwood
> *Lähetetty:* maanantai 17. toukokuuta 2021 15.26
> *Kopio:* mapserver-users at lists.osgeo.org
> *Aihe:* Re: [mapserver-users] differing image size with different
> mapserver versions
> Thanks for the suggestions. The consensus seems to be that anti-aliasing
> is causing the increased size. The documentation here
> <https://mapserver.org/output/antialias.html> says "*Since version 6.0,
> MapServer will produce aliased output for the “gd/” drivers, and
> antialiased output for the “agg/” and “cairo/” ones*" and it's also
> mentioned here
> <https://lists.osgeo.org/pipermail/mapserver-users/2012-April/072011.html> in
> Thomas Bonfort's reply. I actually found that 6.4 produced small, aliased
> images with both the GD and AGG drivers and regardless of my ANTIALIAS
> true/false setting.
> Would anyone consider re-enabling the ANTIALIAS true/false option?
> Thanks,
> Rich
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
Richard W. Greenwood, PLS
www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210517/cfc0138f/attachment.htm>
More information about the MapServer-users
