[mapserver-users] differing image size with different mapserver versions
Even Rouault
even.rouault at spatialys.com
Sat May 15 08:59:06 PDT 2021
Richard,
your 6.4 image is a interlaced PNG, whereas the 7.6 is a non-interlaced one.
I see in the git history a relevant commit:
$ git show 9984b39cc8f74d60eb240728df660a172a118aad
commit 9984b39cc8f74d60eb240728df660a172a118aad
Author: Thomas Bonfort <thomas.bonfort at gmail.com>
Date: Sun Oct 5 15:59:44 2008 +0000
rgba_png: don't interlace by default
git-svn-id: http://svn.osgeo.org/mapserver/trunk@7960
7532c77e-422f-0410-93f4-f0b67bdd69e2
diff --git a/maprgbapng.c b/maprgbapng.c
index 105d8d61..c3615edd 100644
--- a/maprgbapng.c
+++ b/maprgbapng.c
@@ -357,10 +357,13 @@ int msSaveImageRGBAQuantized(gdImagePtr img,
gdIOCtx *ctx, outputFormatObj *form
int bot_idx, top_idx;
int remap[256];
int reqcolors = atoi(msGetOutputFormatOption( format,
"QUANTIZE_COLORS", "256"));
+ const char *interlace;
ms_png_info info;
info.width = gdImageSX(img);
info.height = gdImageSY(img);
- if( strcasecmp("ON", msGetOutputFormatOption( format, "INTERLACE",
"ON" )) == 0 )
+ interlace = msGetOutputFormatOption( format, "INTERLACE", "OFF" );
+ if( strcasecmp("ON", interlace) == 0 || strcasecmp("YES",
interlace) == 0
+ || strcasecmp("1", interlace) == 0)
info.interlaced=1;
else
info.interlaced=0;
But this predates 6.4 release by several years, so this doesn't explain
why you see a different behavior, unless something in 6.4 still turned
on interlacing on in that configuration.
From what I can see in the doc, the interlacing mode was removed in the
7.0 release when GD went off, so I don't think you can do much. I guess
that could be re-added but would require some coding.
Even
Le 15/05/2021 à 17:43, Richard Greenwood a écrit :
> I get significantly different image sizes between MapServer 6.4 and
> 7.6 with the same output format definition. I've tried many variations
> of the following.
> OUTPUTFORMAT
> NAME "png-test"
> DRIVER "AGG/PNG" # GD driver is same (6.4 only)
> MIMETYPE "image/png; mode=8bit"
> IMAGEMODE PC256
> FORMATOPTION "QUANTIZE_FORCE=on"
> FORMATOPTION "QUANTIZE_COLORS=256"
> EXTENSION "png"
> # TRANSPARENT on or off makes little difference
> END
> MapServer 6.4 <https://greenwoodmap.com/mapserv64.png> is 90kB,
> MapServer 7.6 <https://greenwoodmap.com/mapserv76.png> is 320kB. Any
> suggestions as to how I can get my MapServer 7.6 image sizes down
> closer to what I'm getting in MapServer 6.4?
> Thanks,
> Rich
> Richard W. Greenwood, PLS
> www.greenwoodmap.com <http://www.greenwoodmap.com>
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210515/d58d2c74/attachment.html>
