[mapserver-users] Setting up a template for custom WFS GetFeature response
Marcin Grudzień
mgrudzien7 at gmail.com
Tue May 25 01:55:58 PDT 2021
Hello,
I have been trying to set up INSPIRE WFS service publishing data in GML
that validates against INSPIRE GML application schemas. To achieve that I
use template-driven output, basically following
https://mapserver.org/fr/output/template_output.html. However, I am not
able to force MapServer to use my GetFeature response template. GetFeature
response always returns “standard” MapServer GML, which of course, is not
INSPIRE compliant.
Below you can find my configuration details.
I am using 7.6.3 version build on Ubuntu 20.04 LTR
mapserv -v returns
MapServer version 7.6.3 OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=AGG
SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=ICONV SUPPORTS=FRIBIDI
SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER SUPPORTS=WCS_SERVER
SUPPORTS=FASTCGI SUPPORTS=GEOS SUPPORTS=POINT_Z_M SUPPORTS=PBF INPUT=JPEG
INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
My mapfile looks like this
MAP
NAME "LandCover"
STATUS ON
EXTENT 160828.34326572 98928.8977745594 876029.97009323 796521.669409553
UNITS meters
SIZE 100 100
MAXSIZE 4000
FONTSET "/srv/Fonts/Fontset.txt"
CONFIG "MS_ERRORFILE" "/srv/lc/error_lc_wfs.txt"
DEBUG 5
PROJECTION
"init=epsg:2180"
END
OUTPUTFORMAT
NAME "gml"
DRIVER "TEMPLATE"
#MIMETYPE "text/xml; subtype=gml/3.2.1"
FORMATOPTION "FILE=LC_template.gml"
END
WEB
METADATA
"ows_inspire_capabilities" "url"
"ows_languages" "pol,eng"
"ows_title" "Title PL"
"ows_title.eng" "WFS service with INSPIRE Land Cover"
"ows_abstract" "Abstract PL"
"ows_abstract.eng" "WMS service publishes harmonised INSPIRE Land Cover
data set derrived from BDOT10k as-is data set "
"ows_fees" "Brak opłat"
"ows_fees.eng" "No fee applies"
WFS_ONLINERESOURCE "http://localhost/cgi-bin/LC_WFS"
"wfs_getfeature_formatlist" "gml"
"wfs_inspire_metadataurl_href" "someurl"
"wfs_inspire_metadataurl_format"
"application/vnd.ogc.csw.GetRecordByIdResponse_xml"
"ows_inspire_dsid_code" "LC "
"ows_inspire_dsid_ns" "LC.3.2"
"wfs_enable_request" "*"
"wfs_srs" "EPSG:2180 EPSG:4326 EPSG:3857 EPSG:4528"
END
END #WEB
LAYER
NAME "LC.LandCoverUnit"
STATUS ON
CONNECTIONTYPE POSTGIS
CONNECTION "host=localhost dbname=postgis_db user=user
password=password port=5432"
DATA "geom from bdot.landcoversurface using unique objectid
using srid=2180"
PROJECTION
"init=epsg:2180"
END
TYPE POLYGON
PROCESSING "CLOSE_CONNECTION=DEFER"
TEMPLATE "LC_template.gml"
METADATA
"ows_title.pol" "LC.LandCoverUnit"
"ows_title.eng" "LC.LandCoverUnit"
WFS_EXTENT "160828.34326572 98928.8977745594
876029.97009323 796521.669409553"
"gml_include_items" "all"
"gml_featureid" "objectid"
"wfs_connectiontimeout" "120"
"wfs_maxfeatures" "10000"
"wfs_metadataurl_href" "someurl"
"wfs_inspire_metadataurl_format" "application/xml"
"wfs_metadataurl_type" "TC211"
END #METADATA
END #LAYER
END #MAP
I tried different OUTPUTFORMAT configurations with different NAME, MIMETYPE
parameter values. And nothing has worked.
On the same machine, I successfully published WMS service returning HTML
GetFeatureInfo response customized utilizing the very same template-driven
output concept.
I suspect that I may be missing something in the configuration file. I
would be grateful for any suggestions.
Best regards,
Marcin
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210525/e33d3e0f/attachment-0001.html>
