[mapserver-users] Setting up a template for custom WFS GetFeature response
Seth G
sethg at geographika.co.uk
Tue May 25 02:02:52 PDT 2021
Hi Marcin,
What does your GetFeature request look like?
Seth
web:http://geographika.co.uk
twitter: @geographika
On Tue, May 25, 2021, at 10:55 AM, Marcin Grudzień wrote:
> Hello,
> I have been trying to set up INSPIRE WFS service publishing data in GML that validates against INSPIRE GML application schemas. To achieve that I use template-driven output, basically following https://mapserver.org/fr/output/template_output.html. However, I am not able to force MapServer to use my GetFeature response template. GetFeature response always returns “standard” MapServer GML, which of course, is not INSPIRE compliant.
> Below you can find my configuration details.
> I am using 7.6.3 version build on Ubuntu 20.04 LTR
> mapserv -v returns
> MapServer version 7.6.3 OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER SUPPORTS=WCS_SERVER SUPPORTS=FASTCGI SUPPORTS=GEOS SUPPORTS=POINT_Z_M SUPPORTS=PBF INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> My mapfile looks like this
> MAP
> NAME "LandCover"
> STATUS ON
> EXTENT 160828.34326572 98928.8977745594 876029.97009323 796521.669409553
> UNITS meters
> SIZE 100 100
> MAXSIZE 4000
> FONTSET "/srv/Fonts/Fontset.txt"
> CONFIG "MS_ERRORFILE" "/srv/lc/error_lc_wfs.txt"
> DEBUG 5
> PROJECTION
> "init=epsg:2180"
> END
> OUTPUTFORMAT
> NAME "gml"
> DRIVER "TEMPLATE"
> #MIMETYPE "text/xml; subtype=gml/3.2.1"
> FORMATOPTION "FILE=LC_template.gml"
> END
> WEB
> METADATA
> "ows_inspire_capabilities" "url"
> "ows_languages" "pol,eng"
> "ows_title" "Title PL"
> "ows_title.eng" "WFS service with INSPIRE Land Cover"
> "ows_abstract" "Abstract PL"
> "ows_abstract.eng" "WMS service publishes harmonised INSPIRE Land Cover data set derrived from BDOT10k as-is data set "
> "ows_fees" "Brak opłat"
> "ows_fees.eng" "No fee applies"
> WFS_ONLINERESOURCE "http://localhost/cgi-bin/LC_WFS"
> "wfs_getfeature_formatlist" "gml"
> "wfs_inspire_metadataurl_href" "someurl"
> "wfs_inspire_metadataurl_format" "application/vnd.ogc.csw.GetRecordByIdResponse_xml"
> "ows_inspire_dsid_code" "LC "
> "ows_inspire_dsid_ns" "LC.3.2"
> "wfs_enable_request" "*"
> "wfs_srs" "EPSG:2180 EPSG:4326 EPSG:3857 EPSG:4528"
> END
> END #WEB
> LAYER
> NAME "LC.LandCoverUnit"
> STATUS ON
> CONNECTIONTYPE POSTGIS
> CONNECTION "host=localhost dbname=postgis_db user=user password=password port=5432"
> DATA "geom from bdot.landcoversurface using unique objectid using srid=2180"
> PROJECTION
> "init=epsg:2180"
> END
> TYPE POLYGON
> PROCESSING "CLOSE_CONNECTION=DEFER"
> TEMPLATE "LC_template.gml"
> METADATA
> "ows_title.pol" "LC.LandCoverUnit"
> "ows_title.eng" "LC.LandCoverUnit"
> WFS_EXTENT "160828.34326572 98928.8977745594 876029.97009323 796521.669409553"
> "gml_include_items" "all"
> "gml_featureid" "objectid"
> "wfs_connectiontimeout" "120"
> "wfs_maxfeatures" "10000"
> "wfs_metadataurl_href" "someurl"
> "wfs_inspire_metadataurl_format" "application/xml"
> "wfs_metadataurl_type" "TC211"
> END #METADATA
> END #LAYER
> END #MAP
> I tried different OUTPUTFORMAT configurations with different NAME, MIMETYPE parameter values. And nothing has worked.
> On the same machine, I successfully published WMS service returning HTML GetFeatureInfo response customized utilizing the very same template-driven output concept.
> I suspect that I may be missing something in the configuration file. I would be grateful for any suggestions.
> Best regards,
> Marcin
> mapserver-users at lists.osgeo.org <mailto:mapserver-users%40lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210525/41fcc396/attachment-0001.html>
