[mapserver-users] Mapscript C# and OWSRequest parameters
Seth G
sethg at geographika.co.uk
Thu May 27 11:35:02 PDT 2021
Hi Jelmer,
I think you'd have to use mapscript.msIO_installStdinFromBuffer to read data in.
See https://mapserver.org/development/rfc/ms-rfc-16.html#io-hooking although I'm not sure if the approach works or was fully implemented.
Let us know how you get on,
Seth
web:http://geographika.co.uk
twitter: @geographika
On Thu, May 27, 2021, at 10:39 AM, Jelmer Baas wrote:
> Hello,
> For a new project, I’ve decided to pickup MapScript again to function as an internal (back-end) WFS server. I use the OWSRequest class, which works fine when I fill it with loadParamsFromURL() – in the case of Get requests.
> I can’t seem to figure out a way to get my POST data into this object, though. It has a loadParams method, but because I’m not running as a CGI application (back-end app without a webserver), this doesn’t do anything. I also tried setting postrequest property and then calling the loadParams, setting Environment variables, etc. No error, no exception, just -1 value from NumParams.
> Any suggestions on how to proceed?
> Regards,
> Jelmer Baas
> mapserver-users at lists.osgeo.org <mailto:mapserver-users%40lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210527/f9e195ca/attachment-0001.html>
