[mapserver-users] Point query from Mapserver raster
Carl Godkin
cgodkin at gmail.com
Tue Nov 2 08:06:00 PDT 2021
Following Jukka's advice on my elevation point query, I am trying to use
WMS GetFeatureInfo,
I've mostly got it working but have a few more questions. (I am using MS4W
4.0.5 which includes MapServer 7.7.0)
I added a LAYER to my WMS map file:
LAYER
PROCESSING "RESAMPLE=BILINEAR"
NAME SRTM_3_arc-second_grid
METADATA
"wms_title" "SRTM - 3 arc-second grid"
"ows_extent" "-125 24 -66 50"
"wms_include_items" "all"
END
TYPE RASTER
STATUS ON
TILEINDEX "srtm_3_hgt-index.shp"
TILEITEM "Location"
TEMPLATE "../template.html"
PROJECTION
"init=epsg:4326"
END
END
and an empty template except for the
<!-- MapServer Template -->
line. Here's my query:
http://localhost:8080/wms? SERVICE=WMS& VERSION=1.3.0&
REQUEST=GetFeatureInfo& LAYERS=SRTM_3_arc-second_grid& CRS=EPSG:4326& BBOX=
42.94,-122.09,42.95,-122.08& WIDTH=2& HEIGHT=2& X=1& Y=1&
QUERY_LAYERS=SRTM_3_arc-second_grid
This works fine and returns the elevation I am expecting. However, the
MapServer log complains about a "degenerate rect" every time:
[Tue Nov 2 07:58:44 2021].66000 msProjectRect(): Warning: degenerate rect
{-122.082500,42.942500,-122.082500,42.942500}
What am I doing wrong here? As I posted originally, I am really only
interested in a point here.
Thank you very much,
carl
On Mon, Nov 1, 2021 at 12:58 AM Rahkonen Jukka (MML) <
jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Hi,
> The WMS GetFeatureInfo should work and the answer in gis.stackexhange
> seems to contain all the details that you need for making it to work.
> With WCS what you did is probably the best you can do with Mapserver. With
> some other servers you may get a single pixel output by using WCS slicing
> (subset=Long(-100)&subset=Lat(22)) or trimming with lowerlimit=upperlimit
> (subset=Long(-100,-100)&subset=Lat(22,22)) but Mapserver does not support
> either. See https://osgeo-org.atlassian.net/browse/GEOS-9553.
> I could not find a link to an answer by Stefan Meissl about why Mapserver
> does not support slicing but it was about dimensions. A raster image can be
> considered to be two dimensional even when it has only one pixel, but by
> the WCS standard each trim is removing one dimension. Slicing DEM with two
> axes must return a zero dimensional result and raster formats do not
> support that. I still think that subsets with lower=upper limits should
> works and return a single pixel output but that does not work with either
> Mapserver or Geoserver. See also
> https://www.mail-archive.com/search?l=mapserver-users%40lists.osgeo.org&q=subject:%22%5C%5Bmapserver%5C-users%5C%5D+WCS+GetCoverage+request+one++by+one+pixel%22&o=newest&f=1
> -Jukka Rahkonen-
> *Lähettäjä:* MapServer-users <mapserver-users-bounces at lists.osgeo.org> *Puolesta
> *Carl Godkin
> *Lähetetty:* lauantai 30. lokakuuta 2021 2.10
> *Vastaanottaja:* mapserver-users at lists.osgeo.org
> *Aihe:* [mapserver-users] Point query from Mapserver raster
> Hi,
> Now that I have my WMS and WCS servers working well (thanks, list!!), I
> have one more thing I would like to figure out how to do.
> I want to do point queries on [Lat,Lon] points for their elevation from
> the terrain layer I have.
> I have done some searching and come across various ideas such as Raster
> Query (https://mapserver.org/input/raster.html#raster-query) and a query
> template (
> https://gis.stackexchange.com/questions/167239/mapserver-raster-picking-elevation-data)
> but haven't found enough information for either to implement it.
> I came up with a solution that works fine, but might be considered as
> going "All Around the Barn" What works is to add an ASCII output format
> to my map file that serves terrain like this:
> OUTPUTFORMAT
> NAME XYZ
> DRIVER "GDAL/XYZ"
> MIMETYPE "text/plain"
> IMAGEMODE FLOAT32
> EXTENSION "txt"
> END
> and then use GetCoverage on a small rectangle whose lower-left corner
> is the point whose elevation I want:
> http://localhost:8080/wcs?SERVICE=WCS&VERSION=2.0.1&REQUEST=GetCoverage&coverageid=SRTM_3_arc-second_grid&format=XYZ&subset=Lat(42.948,42.958)&subset=Lon(-122.086,-122.076)
> and then take the first line of the returned output file.
> What would Mapserver best practice be for a problem like this?
> Thanks very much,
> carl
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20211102/33637817/attachment-0001.html>
More information about the MapServer-users
