[mapserver-users] How to Turn off a Layer when other specific Layer is ON in a map file ?
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Tue Nov 23 13:42:36 PST 2021
Hi Jeff,
I know REQUIRES has worked in a positive way (show copyright when a layer is on) because I have used that feature but I do not admin that service any more and I can't check the details. Probably I used version 6.x then.
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: MapServer-users <mapserver-users-bounces at lists.osgeo.org> Puolesta Jeff McKenna
Lähetetty: tiistai 23. marraskuuta 2021 23.35
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: Re: [mapserver-users] How to Turn off a Layer when other specific Layer is ON in a map file ?
To give a more detailed example of what *should* work:
   LAYER
     REQUIRES "![modis] OR ![someotherlayername]"
   END
I'll continue my 8.0-dev testing...
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training co-founder of FOSS4G http://gatewaygeo.com/
On 2021-11-23 5:29 p.m., Jeff McKenna wrote:
> Hi Carlos,
> I had a great answer drafted for you, tooting my own horn on the recent
> MapServer tutorial updates for MapServer 8.x, and the demo server
> updates...as by chance the tutorial mentions that the parameter
> "REQUIRES" at the LAYER level should do exactly what you need, super :
> but sadly my tests now fail with MapServer 8.0-dev, I cannot get
> REQUIRES to work, such as:
>    LAYER
>     REQUIRES "![modis]"
>    END
>   where modis is another layer name.
> Since I hadn't been testing this feature, and it is only briefly
> mentioned in the tutorial (and not part of the live demo), I have no way
> of saying when this should have worked, for what MapServer version.  It
> is part of the tutorial mapfiles, but the functionality is not working,
> for my local tests.
> But your question has made me see more room for improvement in the
> tutorial, and its mapfiles, so your question has helped.
> Sorry for my non-news, ha.
> I'll do more testing on this feature and report back.
> -jeff
MapServer-users mailing list
MapServer-users at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
