[mapserver-users] Running on Mac Apache with Hombrew Install of Mapserver 7.6.4
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Thu Nov 18 07:30:18 PST 2021
I have env setting at the top level in httpd.conf. On my Windows I have there also things like
SetEnv PROJ_LIB "/ms4w/proj/nad/"
SetEnv GDAL_DATA "/ms4w/gdaldata"
but you may have those set already as generic environmental variables on your Mac. And you do not need to have directory /opt/mapserver for your mapfiles, you can store them anywhere you want, but MS_MAP_PATTERN must validate the path that you are using.
-Jukka Rahkonen-
Lähettäjä: MapServer-users <mapserver-users-bounces at lists.osgeo.org> Puolesta Kenneth Kniel via MapServer-users
Lähetetty: torstai 18. marraskuuta 2021 17.14
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: [mapserver-users] Running on Mac Apache with Hombrew Install of Mapserver 7.6.4
Working through server issues have not really begun to see maps yet but have verified mapserver is running.
Latest issues is that I am getting the
msCGILoadMap(): Web application error. CGI variable "map" fails to validate.
When I try access demo example-1
I believe I need to add this statement to my http.conf file
SetEnv MS_MAP_PATTERN "^\/opt\/mapserver\/([^\.][_A-Za-z0-9\-\.]+\/{1})*([_A-Za-z0-9\-\.]+\.(map))$"
Maybe I have not looked hard enough but cannot find a /opt/mapserver/ directory in my Homebrew install?
Does it natter where in the https.conf you place this statement?
Anyone dealt with this?
Gettin so close I can almost see a map….:)
Thanks in advance.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20211118/626c2226/attachment.html>
More information about the MapServer-users
