[mapserver-users] Trouble with OpenStreetMap data in MapServer
Carl Godkin
cgodkin at gmail.com
Thu Nov 18 14:03:06 PST 2021
I am following the instructions for using OpenStreetMap data in MapServer
here:
https://github.com/mapserver/mapserver/wiki/RenderingOsmDataWindows
I've been almost all the way through the steps getting everything to work
until I reached the step "Testing with shp2img" which says to run this:
shp2img -m osm-google.map -o output.png -map_debug 3
It fails, like this:
msDrawMap(): rendering using outputformat named png (AGG/PNG).
msDrawMap(): WMS/WFS set-up and query, 0.000s
msPostGISLayerWhichShapes(): Error (out of memory for query result
) executing query: SELECT "name"::text,ST_AsBinary(("geometry"),'NDR') as
geom,"osm_id"::text FROM (select geometry,osm_id, name as name from
osm_new_buildings) as foo WHERE "geometry" &&
ST_GeomFromText('POLYGON((-20037508.3427892
-3113412.49464005,-20037508.3427892 15861721.9613068,-1062373.88684241
15861721.9613068,-1062373.88684241 -3113412.49464005,-20037508.3427892
-3113412.49464005))',3857)
msPostGISLayerWhichShapes(): Query error. Error executing query. Check
server logs
msDrawMap(): Image handling error. Failed to draw layer named 'buildings3'.
<br>
server logs <br>
I don't see anything in the MapServer logs and don't really understand what
is wrong.
I tried specifying individual layers with "-l <layer_name>" to the shp2img
command and most of them work, which I find encouraging.
Specifying layer "buildings3" which failed above still fails when specified
individually.
I'm using Postgres 14, MS4W 4.0.5, MapServer 7.6.4 on Windows 10.
Inspecting the "osm-google.map" file doesn't show me anything very strange
but I'm no expert. I pasted the LAYER section for "buildings3" at the
bottom in case someone spots anything.
(The process used to generate this file is ... well ... amazing!)
I am using data from geofabric.de for the USA (
http://download.geofabrik.de/north-america/us-latest.osm.pbf) downloaded
two days ago.
Does anyone have any suggestions on getting to the bottom of this? I feel
like I'm tantalizingly close!
Thanks a lot,
carl
LAYER
STATUS ON
PROJECTION
"init=epsg:3857"
END
GROUP "default"
NAME "buildings3"
TYPE POLYGON
CONNECTIONTYPE postgis
CONNECTION "host=localhost dbname=osm user=postgres password=postgres
port=5432"
DATA "geometry from (select geometry,osm_id, name as name from
osm_new_buildings) as foo using unique osm_id using srid=3857"
LABELITEM "name"
PROCESSING "LABEL_NO_CLIP=ON"
PROCESSING "CLOSE_CONNECTION=DEFER"
MAXSCALEDENOM 83202051
MINSCALEDENOM 41601025
CLASS
STYLE
COLOR "#bbbbbb"
OPACITY 50
END
STYLE
OUTLINECOLOR "#333333"
WIDTH 0
END
END
END
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20211118/0144b7bc/attachment.html>
More information about the MapServer-users
