[mapserver-users] creating a Mapcache that has the same tile schema as ArcGIS vector tiles
Mark Volz
MarkVolz at co.lyon.mn.us
Fri Oct 22 09:14:32 PDT 2021
Hello,
I would to create an ArcGIS Server cache that uses an equivalent schema as MapServer Mapcache. I would like to know if anyone has a tips to make sure that the schema will work between the products. I am specifically concerned about the tile origin. So here is what I did:
* I am using the same projection on both caches.
* I set the pixel size in ArcGIS to use the same resolutions as MapCache.
* I am using the same tile width and size.
* I am using the same units.
* Of particular concern ArcGIS wants to put the tile origin at -119278400, 141351400 by default while Mapcache uses 436450, 80000.
Anyways, I just wanted to see if I could make the tile cache more compatible between the two systems. Let me know if you have any tips.
Thanks!
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20211022/85deb865/attachment.html>
More information about the MapServer-users
