[mapserver-users] offset and symbolscaledenom
Travis Kirstine
traviskirstine at gmail.com
Wed Sep 1 13:15:22 PDT 2021
Thanks Steve,
I was able to find a workaround.
On Wed, 1 Sept 2021 at 09:54, Steve Lime <sdlime at gmail.com> wrote:
> Not that I know of - unless you did so yourself via MapScript. This seems
> like a limitation of the current implementation rather than a bug. We'd
> need to add additional parameters to limit the offsets (e.g. MINOFFSET,
> MAXOFFSET). --Steve
> On Fri, Aug 27, 2021 at 2:18 PM Travis Kirstine <traviskirstine at gmail.com>
> wrote:
>> Is there a method to scale the offset value between min / max sizes when
>> using symbolscaledenom. I'm trying to scale and offset a label but it
>> appears the offset is static based on the symbolscaledenon.
>> Thanks
>> mapfile
>> LAYER
>> SYMBOLSCALEDENOM 1000
>> CLASS
>> NAME "label"
>> EXPRESSION "POINT"
>> LABEL
>> OFFSET 0 12
>> FONT arial
>> SIZE 12
>> MINSIZE 8
>> MAXSIZE 12
>> TYPE truetype
>> COLOR 0 0 0
>> STYLE
>> GEOMTRANSFORM 'labelpoly'
>> COLOR "#ffffff4f"
>> END
>> END
>> END
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210901/869e67d1/attachment.htm>
More information about the MapServer-users
