[mapserver-users] Handling of NoData in WCS with MapServer
CASTRO, Emmanuel
emmanuel.castro at capgemini.com
Thu Sep 9 01:50:13 PDT 2021
Hello
I have another question about MapServer capabilities. In my technical tests, I am trying to serve a GeoTiff Float32 with a declared NoData value (i.e. -3.4028234663852886e+38).
The GeoTiff file resulting from my WCS request transforms the NoData value to 0, which is problematic because 0 can be a real data.
Is there a way to handle this problem?
I think I can prepare the GeoTiff file by filling the NoData with a value that I control, and then declaring it in the WCS nilValues metadata ; however I would like to avoid preprocessing my input files with gdal_translate or gdal_fillnodata.
Thanks
Emmanuel
This message contains information that may be privileged or confidential and is the property of the Capgemini Group. It is intended only for the person to whom it is addressed. If you are not the intended recipient, you are not authorized to read, print, retain, copy, disseminate, distribute, or use this message or any part thereof. If you receive this message in error, please notify the sender immediately and delete all copies of this message.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210909/a05a59ed/attachment.html>
More information about the MapServer-users
