[mapserver-users] Floating point exception
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri Apr 1 05:38:55 PDT 2022
Ciao Luca,
I had earlier documented by usual PostGIS debugging steps at
https://mapserver.org/optimization/vector.html#debugging-speed-issues-with-postgis
Also, instead of the "-map_debug 3" option with shp2img, try "-all_debug
5" (use "3" if you just want to show the draw speed times)
The goal would be to output the exact query that MapServer is trying to
execute against your database, and then try running that query at the
psql commandline.
And, if all else fails, be sure to retry all of this with a build of
today's MapServer "main" branch, and try with map2img.
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
On 2022-04-01 9:22 a.m., Luca Delucchi wrote:
> Hi all,
> I'm getting "Floating point exception" error running shp2img, also
> running with the debug option I don't get any other information.
> The mapfile read data from PostGIS database, and If I use the same
> mapfile with different database with the same tables I don't get this
> error, so I think the problem is in the data but I don't know
> where/what investigate
> thanks in advance
More information about the MapServer-users
