[mapserver-users] Floating point exception
Luca Delucchi
lucadeluge at gmail.com
Sun Apr 3 08:05:48 PDT 2022
On Fri, 1 Apr 2022 at 14:39, Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
> Ciao Luca,
Ciao Jeff,
> I had earlier documented by usual PostGIS debugging steps at
> https://mapserver.org/optimization/vector.html#debugging-speed-issues-with-postgis
> Also, instead of the "-map_debug 3" option with shp2img, try "-all_debug
> 5" (use "3" if you just want to show the draw speed times)
I tried also with -all_debug but no debug messages appears only the error
> The goal would be to output the exact query that MapServer is trying to
> execute against your database, and then try running that query at the
> psql commandline.
> And, if all else fails, be sure to retry all of this with a build of
> today's MapServer "main" branch, and try with map2img.
Ok, I will try in the next days
> -jeff
ciao
Luca
www.lucadelu.org
More information about the MapServer-users
