[mapserver-users] Floating point exception
Luca Delucchi lucadeluge at gmail.com
Fri Apr 8 01:38:41 PDT 2022
I compiled the github master version and used map2img, the output is
not helping so much...
map2img -m eurodeer_new.map -o eurodeer.png -all_debug 5
Cannot open configuration file /usr/local/etc/mapserver.conf.
msLoadConfig(): Unable to access file. See
mapserver.org/config_file.html for more information.
msDrawMap(): Image handling error. Failed to draw layer named
'Research groups'. <br>
msPostGISLayerWhichShapes(): Query error. Failed to build query SQL. <br>
msPostGISBuildSQL(): General error message. Failed to build SQL 'where'. <br>
msSearchDiskTree(): Search returned no results. Unable to open spatial
index for /home/lucadelu/github/euromammals/print_maps/././data/ne_10m_admin_0_sovereignty.qix.
In most cases you can safely ignore this message, otherwise check file
names and permissions. <br>
mapserver.org/config_file.html for more information. <br>
the 'Research groups' layer is defined like this
DATA "geom from (select research_groups_id, short_name, geom from
main.research_groups where ST_Contains(!BOX!, geom)) as subquery using
unique research_groups_id using srid=4326"
ciao
Luca
www.lucadelu.org
More information about the MapServer-users mailing list
