[mapserver-users] Floating point exception
Even Rouault even.rouault at spatialys.com
Fri Apr 8 05:20:06 PDT 2022
Build with cmake -DCMAKE_BUILD_TYPE=Debug
and run under gdb:
gdb --args map2img -m eurodeer_new.map -o eurodeer.png -all_debug 5
-conf /path/to/conffile
run
and when it crashes
bt
Le 08/04/2022 à 10:38, Luca Delucchi a écrit :
> Hi,
> I compiled the github master version and used map2img, the output is
> not helping so much...
> Cannot open configuration file /usr/local/etc/mapserver.conf.
> msLoadConfig(): Unable to access file. See
> mapserver.org/config_file.html for more information.
> msDrawMap(): Image handling error. Failed to draw layer named
> 'Research groups'. <br>
> msPostGISLayerWhichShapes(): Query error. Failed to build query SQL. <br>
> msPostGISBuildSQL(): General error message. Failed to build SQL 'where'. <br>
> msSearchDiskTree(): Search returned no results. Unable to open spatial
> index for /home/lucadelu/github/euromammals/print_maps/././data/ne_10m_admin_0_sovereignty.qix.
> In most cases you can safely ignore this message, otherwise check file
> names and permissions. <br>
> mapserver.org/config_file.html for more information. <br>
> the 'Research groups' layer is defined like this
> DATA "geom from (select research_groups_id, short_name, geom from
> main.research_groups where ST_Contains(!BOX!, geom)) as subquery using
> unique research_groups_id using srid=4326"
http://www.spatialys.com
More information about the MapServer-users mailing list
