[mapserver-users] FlatGeoBuf access (and WFS output) steps in MapServer
Jeff McKenna jmckenna at gatewaygeomatics.com
Mon Apr 25 12:32:12 PDT 2022
Hi all,
I've spent some effort to document how to enable the optimized
FlatGeobuf (FGB) format for vectors in MapServer, for both
reading/access as well as steps to output FGB through WFS (you could
also use these same steps for WMS GetFeatureInfo output of FGB as well):
  https://mapserver.org/input/vector/flatgeobuf.html
The user community might be interested also in some performance testing
that I've done with FlatGeobuf with MapServer (hardcore developers might
question my exact methods, but for general users these results should be
interesting).  I've added the results as a note in the Vector
Optimization document ( https://mapserver.org/optimization/vector.html )
I used shp2img/map2img to test the map drawing speed for a few popular
vector formats (note that these are averaged times, and are not done on
a cold connection), with the latest MapServer 8.0-dev code on Windows
through MS4W:
   Shapefile  0.011s
   FlatGeobuf 0.014s
   GeoPackage 0.042s
   SpatiaLite 0.045s
   PostGIS    0.053s
   GeoJSON    0.089s
The point is not to cause controversy or start analyzing my simple
testing methods, but instead to generally show how optimized FlatGeobuf
is for rendering (and filtering) in MapServer, and that we should all be
considering this format for sharing vectors through our MapServer services.
Thanks,
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
More information about the MapServer-users mailing list
