[MapServer-users] Problems with vrt created from GCP raster
Marcin Niemyjski
mniemyjski at cloudferro.com
Tue Dec 6 10:07:53 PST 2022
Scott,
1. gdalbuildvrt doesnt work with raster georeferenced by ground control points. Thats why I am using gdal warp -> https://gis.stackexchange.com/questions/283595/transform-rectify-unprojected-raster-using-target-extent-co-ordinates
2. Source files are already in cloud optimized format
Do you have any other ideas?
Best,
Marcin
Wysyłane z aplikacji Outlook dla systemu iOS<https://aka.ms/o0ukef>
Od: MapServer-users <mapserver-users-bounces at lists.osgeo.org> w imieniu użytkownika Scott <public at postholer.com>
Wysłane: Tuesday, December 6, 2022 6:39:00 PM
Do: mapserver-users at lists.osgeo.org <mapserver-users at lists.osgeo.org>
Temat: Re: [MapServer-users] Problems with vrt created from GCP raster
My "first is worst" suggestion would be to create a .vrt for each day:
gdalbuildvrt Day1.vrt [date]*.tif
gdalbuildvrt Day2.vrt [date]*.tif
Next, in your .map file use runtime substitution:
DATA "/file/path/Day%day%.vrt"
If you really want to make this fast, convert all your source .tif's to
format COG. All you tif's will be tiled:
gdalwarp -f COG -co COMPRESS=DEFLATE -co BIGTIFF=YES sent.tif sent_cog.tif
On 12/6/22 09:18, Marcin Niemyjski via MapServer-users wrote:
> Hello,
> up to now, I have been working with VRT as a carrier for the rasters I
> wanted to use in the mapfile. Now in order to use the rasters that were
> provided to me (they are GCP georeferenced rasters) I have to convert
> them to VRT(via gdal warp), hence my question - how can I mosaic the
> rasters within one layer in Mapserver (one layer = one day of photos
> from Sentinel-2 for example). I can't create vrt to existing vrt, and
> creating a tileindex for each layer generates too many files. I wanted
> to create one vrt gathering together all of raster but gdal_warp uses
> only the first one as data source.
> What can I do?
> Best regards,
> Marcin
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20221206/dacd95f1/attachment.htm>
More information about the MapServer-users
