[MapServer-users] Problems with vrt created from GCP raster
Scott
public at postholer.com
Tue Dec 6 10:19:19 PST 2022
The only thing I can think of is create an entirely new .tif from your
gcp .tif, then it shouldn't be a problem.
However, this could result a very large set of new sentinel tifs. Bad.
On 12/6/22 10:07, Marcin Niemyjski wrote:
> Scott,
> 1. gdalbuildvrt doesnt work with raster georeferenced by ground control
> points. Thats why I am using gdal warp ->
> https://gis.stackexchange.com/questions/283595/transform-rectify-unprojected-raster-using-target-extent-co-ordinates <https://gis.stackexchange.com/questions/283595/transform-rectify-unprojected-raster-using-target-extent-co-ordinates>
> 2. Source files are already in cloud optimized format
> Do you have any other ideas?
> Best,
> Marcin
> Wysyłane z aplikacji Outlook dla systemu iOS <https://aka.ms/o0ukef>
> *Od:* MapServer-users <mapserver-users-bounces at lists.osgeo.org> w
> imieniu użytkownika Scott <public at postholer.com>
> *Wysłane:* Tuesday, December 6, 2022 6:39:00 PM
> *Do:* mapserver-users at lists.osgeo.org <mapserver-users at lists.osgeo.org>
> *Temat:* Re: [MapServer-users] Problems with vrt created from GCP raster
> My "first is worst" suggestion would be to create a .vrt for each day:
> gdalbuildvrt Day1.vrt [date]*.tif
> gdalbuildvrt Day2.vrt [date]*.tif
> Next, in your .map file use runtime substitution:
> DATA "/file/path/Day%day%.vrt"
> If you really want to make this fast, convert all your source .tif's to
> format COG. All you tif's will be tiled:
> gdalwarp -f COG -co COMPRESS=DEFLATE -co BIGTIFF=YES sent.tif sent_cog.tif
> On 12/6/22 09:18, Marcin Niemyjski via MapServer-users wrote:
>> Hello,
>> up to now, I have been working with VRT as a carrier for the rasters I
>> wanted to use in the mapfile. Now in order to use the rasters that were
>> provided to me (they are GCP georeferenced rasters) I have to convert
>> them to VRT(via gdal warp), hence my question - how can I mosaic the
>> rasters within one layer in Mapserver (one layer = one day of photos
>> from Sentinel-2 for example). I can't create vrt to existing vrt, and
>> creating a tileindex for each layer generates too many files. I wanted
>> to create one vrt gathering together all of raster but gdal_warp uses
>> only the first one as data source.
>> What can I do?
>> Best regards,
>> Marcin
>> MapServer-users mailing list
>> MapServer-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
> <https://lists.osgeo.org/mailman/listinfo/mapserver-users>
More information about the MapServer-users
