[mapserver-users] How to reference ESRI projections that are already in proj.db
Mark Volz
MarkVolz at co.lyon.mn.us
Fri Feb 25 09:44:33 PST 2022
Hello,
I am having trouble trying to reference ESRI authority coordinate systems that are within proj.db within MapServer. I know this should work because I can use the QGIS can use the ESRI authority coordinate systems and QGIS apparently uses the same proj.db database as MapServer. I tried referencing the projection using init=esri:103749 and init=epsg 103749. Neither option appears to work. I can however manually and the projection parameters.
Here is a snippet of my code:
MAP
PROJECTION
"init=epsg:4326"
END #Map Projection
LAYER
PROJECTION
#WORKS
"+proj=lcc +lat_1=44.25 +lat_2=44.58333333333334 +lat_0=44.19555555555555 +lon_0=-95.85000000000001 +x_0=152400.3048006096 +y_0=30480.06096012192 +a=6378559.758 + b=6357173.65471281 +units=ft +no_defs <>"
#Does not work
"init=esri:103749"
"init=esri:103749"
End #Layer projection
END #Layer
END #Map
Please let me know if you have any thoughts regarding how we can use ESRI authority projections.
Thank You
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20220225/6c365119/attachment.html>
More information about the MapServer-users
