[mapserver-users] How to reference ESRI projections that are already in proj.db
Even Rouault
even.rouault at spatialys.com
Fri Feb 25 10:06:03 PST 2022
A tweak in MapServer code would be required to accept syntax like
"ESRI:XXXXX". The +init=epsg: stuff that is a compatibility syntax which
only works for EPSG.
Le 25/02/2022 à 18:44, Mark Volz a écrit :
> Hello,
> I am having trouble trying to reference ESRI authority coordinate
> systems that are within proj.db within MapServer. I know this should
> work because I can use the QGIS can use the ESRI authority coordinate
> systems and QGIS apparently uses the same proj.db database as
> MapServer. I tried referencing the projection using init=esri:103749
> and init=epsg 103749. Neither option appears to work. I can however
> manually and the projection parameters.
> Here is a snippet of my code:
> MAP
> PROJECTION
> "init=epsg:4326"
> END #Map Projection
> LAYER
> PROJECTION
> #WORKS
> "+proj=lcc +lat_1=44.25 +lat_2=44.58333333333334
> +lat_0=44.19555555555555 +lon_0=-95.85000000000001
> +x_0=152400.3048006096 +y_0=30480.06096012192 +a=6378559.758 +
> b=6357173.65471281 +units=ft +no_defs <>"
> #Does not work
> “init=esri:103749”
> “init=esri:103749”
> End #Layer projection
> END #Layer
> END #Map
> Please let me know if you have any thoughts regarding how we can use
> ESRI authority projections.
> Thank You
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20220225/0673e9f2/attachment.html>
More information about the MapServer-users
