[mapserver-users] How to reference ESRI projections that are already in proj.db
Even Rouault
even.rouault at spatialys.com
Fri Feb 25 12:41:41 PST 2022
Tweak implemented in https://github.com/MapServer/MapServer/pull/6484
Le 25/02/2022 à 19:06, Even Rouault a écrit :
> A tweak in MapServer code would be required to accept syntax like
> "ESRI:XXXXX". The +init=epsg: stuff that is a compatibility syntax
> which only works for EPSG.
> Le 25/02/2022 à 18:44, Mark Volz a écrit :
>> Hello,
>> I am having trouble trying to reference ESRI authority coordinate
>> systems that are within proj.db within MapServer. I know this
>> should work because I can use the QGIS can use the ESRI authority
>> coordinate systems and QGIS apparently uses the same proj.db database
>> as MapServer. I tried referencing the projection using
>> init=esri:103749 and init=epsg 103749. Neither option appears to
>> work. I can however manually and the projection parameters.
>> Here is a snippet of my code:
>> MAP
>> PROJECTION
>> "init=epsg:4326"
>> END #Map Projection
>> LAYER
>> PROJECTION
>> #WORKS
>> "+proj=lcc +lat_1=44.25 +lat_2=44.58333333333334
>> +lat_0=44.19555555555555 +lon_0=-95.85000000000001
>> +x_0=152400.3048006096 +y_0=30480.06096012192 +a=6378559.758 +
>> b=6357173.65471281 +units=ft +no_defs <>"
>> #Does not work
>> “init=esri:103749”
>> “init=esri:103749”
>> End #Layer projection
>> END #Layer
>> END #Map
>> Please let me know if you have any thoughts regarding how we can use
>> ESRI authority projections.
>> Thank You
>> MapServer-users mailing list
>> MapServer-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20220225/a8daf51b/attachment.html>
More information about the MapServer-users
