[mapserver-users] How to limit the width of the outline when the symbol size changes with the map scale?
Kyle Qian
kyleqian at gmail.com
Sun Feb 27 01:42:03 PST 2022
thank you. it seems to be a acceptable solution.
Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi> 于 2022年2月26日周六
22:19写道:
> Hi,
> Have you tried to use two filled circle symbols for making the outline
> effect, one below and the other one above? Or to use png image as a symbol?
> -Jukka Rahkonen-
> *Lähettäjä:* MapServer-users <mapserver-users-bounces at lists.osgeo.org> *Puolesta
> *Kyle Qian
> *Lähetetty:* lauantai 26. helmikuuta 2022 1.58
> *Vastaanottaja:* Jason Snyder <mapserver-users at lists.osgeo.org>
> *Aihe:* Re: [mapserver-users] How to limit the width of the outline when
> The map file I used is:
> CLASS
> NAME "Populated Places"
> STYLE
> SYMBOL "PT-1"
> COLOR "#00A2E8"
> OPACITY 100
> MINSIZE 10
> MAXSIZE 30
> SIZE 16.5
> OFFSET 0 0
> OUTLINECOLOR "#FF0000"
> OUTLINEWIDTH 5
> END
> END
> SYMBOLSCALEDENOM 68247.34668319309
> SYMBOL
> NAME "PT-1"
> TYPE ellipse
> FILLED true
> POINTS 5 5 END
> END
> Kyle Qian <kyleqian at gmail.com> 于2022年2月26日周六 07:56写道:
> Hi, when I set up a map for points, I use SYMBOLSCALEDENOM to change
> the size of points and MIN/MAXSIZE to limit it, but there seems to be no
> way to control the width of the outline of points. The outline seems to
> keep getting bigger as the map zooms in. The image below is the result map
> as the map zooms in:
> https://pasteboard.co/JC19o7caYHHk.png
> Is there any way to solve this problem?
> In addition, it seems that there is no way to set the transparency of the
> outline separately. Is it necessary to use a separate STYLE to implement it
> with GEOMTRANSFORM?
> Thanks.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20220227/37dfb545/attachment.html>
More information about the MapServer-users
