[mapserver-users] WCS layer units question...
Carl Godkin
cgodkin at gmail.com
Wed Jan 12 16:44:31 PST 2022
Hi Jukka,
Thanks for the documentation pointer. I have attached a .map file in which
I have all three of the possibilities
# Trying all three. My single band is called "band"
"wcs_band_uom" "m"
"ows_band_uom" "m"
"band_band_uom" "m"
but I still only see
<swe:uom code="W.m-2.Sr-1"/>
from DescribeCoverage. I am very curious to know what I've overlooked!
By the way, I'm running MapServer from the "camptocamp" docker image. It
appears to by MapServer 7.7-dev.
Thanks so much,
carl
On Wed, Jan 12, 2022 at 9:47 AM Rahkonen Jukka (MML) <
jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Hi,
> Sorry, I thought that our service is open. This should work
> https://demo.mapserver.org/cgi-bin/wcs?SERVICE=wcs&VERSION=2.0.0&REQUEST=DescribeCoverage&COVERAGEID=modis
> The default value of uom is documented in
> https://www.mapserver.org/ogc/wcs_server.html
> “If no specific or default value is given, the output is dependent on the
> metadata key. The UOM, for example will be set to ‘W.m-2.Sr-1’”
> WCS metadata keywords, including “{band_name}_band_uom” work for us. I am
> sure that you will make it to work as well but if you won’t, show us your
> mapfile.
> -Jukka Rahkonen-
> *Lähettäjä:* MapServer-users <mapserver-users-bounces at lists.osgeo.org> *Puolesta
> *Carl Godkin
> *Lähetetty:* keskiviikko 12. tammikuuta 2022 17.13
> *Vastaanottaja:* Mapserver-Users (mapserver-users at lists.osgeo.org) <
> mapserver-users at lists.osgeo.org>
> *Aihe:* Re: [mapserver-users] WCS layer units question...
> Thanks for the reply, Jukka.
> I found "wcs_band_uom" in the docs but I can't seem to make the value I
> put into my map file appear in the DescribeCoverage output. (The link you
> sent doesn't work for me.)
> I do see this though:
> <swe:field name="band">
> <swe:Quantity>
> <swe:nilValues/>
> <swe:constraint>
> <swe:AllowedValues>
> <swe:interval>-3.4028e+38 3.4028e+38</swe:interval>
> <swe:significantFigures>12</swe:significantFigures>
> </swe:AllowedValues>
> </swe:constraint>
> </swe:Quantity>
> </swe:field>
> The "swe:uom code" would seem to be what I want to affect. For some
> reason I see the value "watts per square meter per steradian" which appears
> nowhere in my map file so I wonder if it's some sort of default baked into
> the code or something. (I had seen that before but hadn't bothered to try
> to figure out what it was until just now. That's weird.)
> Thanks for your help,
> carl
> On Tue, Jan 11, 2022 at 11:57 PM Rahkonen Jukka (MML) <
> Hi,
> WCS users are supposed to read the metadata with DescribeCoverage, for
> example
> https://avoin-visukuva.nls.fi/ortokuvat-ja-korkeusmallit/wcs/v1?service=WCS&version=2.0.1&request=DescribeCoverage&coverageID=ortokuva_vari
> The units can be configured in the mapfile with “wcs_band_uom”. I do not
> know if it is possible to configure the outputformat to write uom also into
> the TIFF. That is something that GDAL should do.
> -Jukka Rahkonen-
> *Carl Godkin
> *Lähetetty:* keskiviikko 12. tammikuuta 2022 3.58
> *Aihe:* [mapserver-users] WCS layer units question...
> Hi,
> I have a local WCS & WMS server.
> I am trying to figure out if I can somehow define the Z units of a terrain
> layer I'm serving.
> The single band from the individual GeoTIFF files providing the terrain
> data looks like this (from gdalinfo):
> Band 1 Block=512x512 Type=Float32, ColorInterp=Gray
> Description = Layer_1
> NoData Value=-999999
> Unit Type: m <===================================== units are meters
> Metadata:
> LAYER_TYPE=athematic
> RepresentationType=ATHEMATIC
> but when I download a GeoTIFF using a WCS GetCoverage request on this
> layer, the GeoTIFF's single band just looks like this:
> Band 1 Block=571x3 Type=Float32, ColorInterp=Gray
> without "Unit Type."
> I also tried using
> UNITS Meters
> in my LAYER definition in my map file (copying an example I found among
> the case studies on the web site) but it didn't seem to have any effect.
> Is there some way to define and retrieve the Z units for a WCS server?
> Thanks very much.
> carl
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20220112/83075980/attachment.htm>
MAP
NAME "example" # Short name prepended to map, legend and scalebar filenames
STATUS OFF
SIZE 800 600
EXTENT -180 -90 180 90
UNITS DD
# Path to folder holding the tile index shapefiles
SHAPEPATH "data"
IMAGECOLOR 255 255 255 # Background color for transparency
MAXSIZE 8192
#CONFIG "MS_ERRORFILE" "tmp/ms_error.txt"
# 0-5: 0=Off, 1-5=level of detail written to ms_error.txt
DEBUG 5
WEB
# Path for temp files; must be writable by www-data
IMAGEPATH "tmp/"
IMAGEURL "/ms_tmp/" # Base URL for IMAGEPATH.
METADATA
"ows_abstract" "WMS & WCS Elevation Service"
"ows_contactfacsimiletelephone" ""
"ows_contactinstructions" ""
"ows_enable_request" "*"
"ows_hoursofservice" ""
"ows_onlineresource" "http://localhost:8080/"
"ows_role" ""
"ows_srs" "EPSG:4326 EPSG:4269 EPSG:3857"
"ows_updatesequence" "2015-02-27T16:26:00Z"
"wcs_accessconstraints" "none"
"wcs_description" "Terrain server"
"wcs_enable_request" "*"
"wcs_fees" "none"
"wcs_keywordlist" "wcs,test"
"wcs_label" "P2 WCS Server" ### required
"wcs_metadatalink_format" "text/plain"
"wcs_metadatalink_type" "TC211"
"wcs_onlineresource" "http://localhost:8080/" ### recommended
"wcs_service_onlineresource" "http://localhost:8080/"
"wms_rootlayer_name" "" # Suppresses root layer in gdalinfo
"wcs_band_uom" "m"
"ows_band_uom" "m"
"band_band_uom" "m"
END
END
#define your output projection
PROJECTION
"init=epsg:4269"
END
#define output formats
OUTPUTFORMAT
NAME GEOTIFF
DRIVER "GDAL/GTiff"
MIMETYPE "image/geotiff"
IMAGEMODE RGB
EXTENSION "tif"
END
OUTPUTFORMAT
NAME "GEOTIFF_32"
DRIVER "GDAL/GTiff"
MIMETYPE "image/tiff"
IMAGEMODE FLOAT32
EXTENSION "tif"
END
# Start of layer definitions
LAYER
PROCESSING "RESAMPLE=BILINEAR"
NAME USGS_13as_elevation
METADATA
"wms_title" "USGS - 1/3 arc-second grid (western US)"
"ows_extent" "-126 30.999444 -110.999444 50.000556"
"wms_include_items" "x,y,value_0"
"wcs_label" "USGS - 1/3 arc-second grid" ### required
"wcs_rangeset_name" "Range 1" ### required to support DescribeCoverage request
"wcs_rangeset_label" "USA" ### required to support DescribeCoverage request
"wcs_resolution" "0.000092592592593 0.000092592592593"
"wcs_bandcount" "1"
"wcs_srs" "EPSG:4269"
END
TYPE RASTER ### required
UNITS Meters
STATUS ON
TILEINDEX "usgs_13as_elevation-index.shp" # Path is relative to SHAPEPATH
TILEITEM "Location"
TEMPLATE "../template.html"
PROJECTION
"init=epsg:4269"
END
END
END
More information about the MapServer-users
