[mapserver-users] WCS layer units question...
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Thu Jan 13 01:08:18 PST 2022
I can only tell that with these metadata settings in my mapfile
METADATA
"wcs_label" "orto_vv" ### required
"wcs_resolution" "0.5 0.5"
"wcs_imagemode" "BYTE"
"wcs_bandcount" "3"
"wcs_band_names" "Band1 Band2 Band3"
"wcs_timeposition" "2000-11-11T11:11:11Z,2001-11-11T11:11:11Z"
"Band1_band_description" "NIR range 700-900 nm"
"Band2_band_description" "Red range 600-700 nm"
"Band3_band_description" "Green range 500-600"
"Band1_band_uom" "foo"
"Band2_band_uom" "bar"
"Band3_band_uom" "foobar"
"wcs_rangeset_axis" "E,N"
"wcs_extent" "212000.000 6762000.000 218000.000 6768000.000"
"wcs_rangeset_name" "Range 1" ### required to support DescribeCoverage request
"wcs_rangeset_label" "My Label" ### required to support DescribeCoverage request
END
I can see for example this in DescribeCoverage
<swe:field name="Band3">
<swe:Quantity>
<swe:description>Green range 500-600</swe:description>
<swe:nilValues/>
<swe:uom code="foobar"/>
I have the same version 7.7.0-dev (MS4W 4.0.5).
-Jukka Rahkonen-
Lähettäjä: MapServer-users <mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org>> Puolesta Carl Godkin
Lähetetty: torstai 13. tammikuuta 2022 2.45
Vastaanottaja: Mapserver-Users (mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>) <mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>>
Aihe: Re: [mapserver-users] WCS layer units question...
Hi Jukka,
Thanks for the documentation pointer. I have attached a .map file in which I have all three of the possibilities
# Trying all three. My single band is called "band"
"wcs_band_uom" "m"
"ows_band_uom" "m"
"band_band_uom" "m"
but I still only see
<swe:uom code="W.m-2.Sr-1"/>
from DescribeCoverage. I am very curious to know what I've overlooked!
By the way, I'm running MapServer from the "camptocamp" docker image. It appears to by MapServer 7.7-dev.
Thanks so much,
carl
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20220113/56e3420f/attachment.htm>
More information about the MapServer-users
