[mapserver-users] working with ESRI coordinate systems in proj.db
Steve Lime
sdlime at gmail.com
Thu Jan 6 15:24:31 PST 2022
Hi Mark: Not something I've tried to do so hopefully someone else can weigh
in. What version of Proj are you using? --Steve
On Thu, Jan 6, 2022 at 11:19 AM Mark Volz <MarkVolz at co.lyon.mn.us> wrote:
> Hello,
> Could someone help me with setting up mapserver to use a non ESRI
> projection that is already stored in proj.db? The coordinate system is for
> Lyon County, MN #103749 and is stored with ESRI as the authority. I know
> that we can set up Mapserver to use Web Mercator by setting the adding
> "init=epsg:4326" to a projection block. Unfortunately I cannot access my
> counties coordinate system by setting the projection with
> “init=esri:103749”.
> Thank you for any help!
> Sincerely,
> *Mark Volz, GISP*
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20220106/0211725b/attachment.html>
More information about the MapServer-users
