[mapserver-users] [MapServer-users] working with ESRI coordinate systems in proj.db
Basques, Bob (CI-StPaul)
bob.basques at ci.stpaul.mn.us
Fri Jan 7 07:13:52 PST 2022
Mark, will this work : https://epsg.io/6505 or are you trying to import data from your ESRI service.
We (Jim) went a little different route here, we read the ESRI rest service and stuff everything into a Postgres database as a cache and work against that. We can set whatever EPSG that we need to this way for interoperability.
Bobb
From: MapServer-users <mapserver-users-bounces at lists.osgeo.org> on behalf of Mark Volz <MarkVolz at co.lyon.mn.us>
Date: Friday, January 7, 2022 at 8:20 AM
To: Steve Lime <sdlime at gmail.com>
Cc: "mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
Subject: Re: [mapserver-users] [MapServer-users] working with ESRI coordinate systems in proj.db
Think Before You Click: This email originated outside our organization.
Steve,
I am using ms4w version 4.0.5, which I think comes with PROJ 5.20
Thank You
Hi Mark: Not something I've tried to do so hopefully someone else can weigh in. What version of Proj are you using? --Steve
On Thu, Jan 6, 2022 at 11:19 AM Mark Volz <MarkVolz at co.lyon.mn.us<mailto:MarkVolz at co.lyon.mn.us>> wrote:
Hello,
Could someone help me with setting up mapserver to use a non ESRI projection that is already stored in proj.db? The coordinate system is for Lyon County, MN #103749 and is stored with ESRI as the authority. I know that we can set up Mapserver to use Web Mercator by setting the adding "init=epsg:4326" to a projection block. Unfortunately I cannot access my counties coordinate system by setting the projection with “init=esri:103749”.
Thank you for any help!
Sincerely,
Mark Volz, GISP
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20220107/c3045eb8/attachment-0001.html>
More information about the MapServer-users
