[mapserver-users] [MapServer-users] working with ESRI coordinate systems in proj.db
Pericles Nacionales
naci0002 at umn.edu
Fri Jan 7 07:12:42 PST 2022
Mark,
Haven't done this in a while but what happens if you replace "esri:103749"
with "epsg:103749"?
-Perry
On Fri, Jan 7, 2022, 08:20 Mark Volz <MarkVolz at co.lyon.mn.us> wrote:
> Steve,
> I am using ms4w version 4.0.5, which I think comes with PROJ 5.20
> Thank You
> Hi Mark: Not something I've tried to do so hopefully someone else can
> weigh in. What version of Proj are you using? --Steve
> On Thu, Jan 6, 2022 at 11:19 AM Mark Volz <MarkVolz at co.lyon.mn.us> wrote:
> Hello,
> Could someone help me with setting up mapserver to use a non ESRI
> projection that is already stored in proj.db? The coordinate system is for
> Lyon County, MN #103749 and is stored with ESRI as the authority. I know
> that we can set up Mapserver to use Web Mercator by setting the adding
> "init=epsg:4326" to a projection block. Unfortunately I cannot access my
> counties coordinate system by setting the projection with
> “init=esri:103749”.
> Thank you for any help!
> Sincerely,
> *Mark Volz, GISP*
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20220107/f55bbb4d/attachment.html>
More information about the MapServer-users
