[mapserver-users] Mapserver 8, PHP 8 and Mapscript
Sven Schroeter schroeter at netgis.de
Thu Jul 21 02:54:29 PDT 2022
I have a Problem compiling with Mapserver 8, PHP 8 and Mapscript on
Debian 11 Bullseye
I have downloaded Mapserver 8.0 beta and configured it as follows:
|cmake-DCMAKE_INSTALL_PREFIX=/opt \|
|-DCMAKE_PREFIX_PATH=/usr/local:/opt \|
|-DWITH_CLIENT_WFS=ON \|
|-DWITH_CLIENT_WMS=ON \|
|-DWITH_WCS=ON \|
|-DWITH_THREAD_SAFETY=ON \|
|-DWITH_PHP=ON \|
|-DWITH_KML=ON \|
|-DWITH_GEOS=ON \|
|-DWITH_GDAL=ON \|
|-DWITH_OGR=ON \|
|-DWITH_PROJ=ON \|
|-DWITH_CAIRO=ON \|
|-DWITH_POSTGIS=ON \|
|-DWITH_CURL=ON \|
|-DWITH_SOS=ON \|
|-DWITH_XMLMAPFILE=0 \|
|-DWITH_FCGI=ON \|
|-DWITH_LIBXML2=ON \|
|-DWITH_GIF=ON \|
|-DWITH_FRIBIDI=0 \|
|-DWITH_HARFBUZZ=0 \|
|-DWITH_PROTOBUFC=0 \|
|-DWITH_PYTHON=OFF \|
|-DWITH_SVGCAIRO=OFF \|
  When I use Mapserver 7.6.4 in the same setup, the following lines appear:
-- /usr/include/php/20200930/main
-- Found PHP-Version 8.0.21 (using /usr/bin/php-config)
In Mapserver 8 these are missing and accordingly the output in
mapscripts is:
--* Mapscripts
--* Python: disabled
--* PHPNG: disabled
That means PHP is not activated. In comparison the output with Mapserver
7.6.4:
--* Mapscripts
--* PHP: ENABLED
--* PHPNG: disabled
It is the same server with the same installation components.
Accordingly, in a make and make under Version 8 install PHP Mapscript is
not installed.
php - v generates the following
Unable to load dynamic library 'php_mapscript.so' (tried:
/usr/lib/php/20200930/php_mapscript.so
(/usr/lib/php/20200930/php_mapscript.so: cannot open shared object file:
No such file or directory), /usr/lib/php/20200930/php_mapscript.so.so
(/usr/lib/php/20200930/php_mapscript.so.so: cannot open shared object
file: No such file or directory)) in Unknown on line 0
Note: PHP is installed with FPM module (php8.0-fpm) and instead of
mpm_prefork mpm_event is used.
Any idea?
Thanks Sven
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20220721/c351e438/attachment.htm>
More information about the MapServer-users mailing list
