[mapserver-users] Mapserver 8, PHP 8 and Mapscript
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu Jul 21 06:00:07 PDT 2022
Hi Sven,
For MapServer 8 (and beyond) you will need to enable the switch
"-DWITH_PHPNG" to enable PHP MapScript through SWIG, as the old
unmaintained PHP native MapScript has been removed for MapServer 8.
(I hope I am understanding your question correctly)
Thanks,
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
On 2022-07-21 6:54 a.m., Sven Schroeter wrote:
> Hi,
> I have a Problem compiling with Mapserver 8, PHP 8 and Mapscript on
> Debian 11 Bullseye
> I have downloaded Mapserver 8.0 beta and configured it as follows:
> |cmake-DCMAKE_INSTALL_PREFIX=/opt \|
> |-DCMAKE_PREFIX_PATH=/usr/local:/opt \|
> |-DWITH_CLIENT_WFS=ON \|
> |-DWITH_CLIENT_WMS=ON \|
> |-DWITH_WCS=ON \|
> |-DWITH_THREAD_SAFETY=ON \|
> |-DWITH_PHP=ON \|
> |-DWITH_KML=ON \|
> |-DWITH_GEOS=ON \|
> |-DWITH_GDAL=ON \|
> |-DWITH_OGR=ON \|
> |-DWITH_PROJ=ON \|
> |-DWITH_CAIRO=ON \|
> |-DWITH_POSTGIS=ON \|
> |-DWITH_CURL=ON \|
> |-DWITH_SOS=ON \|
> |-DWITH_XMLMAPFILE=0 \|
> |-DWITH_FCGI=ON \|
> |-DWITH_LIBXML2=ON \|
> |-DWITH_GIF=ON \|
> |-DWITH_FRIBIDI=0 \|
> |-DWITH_HARFBUZZ=0 \|
> |-DWITH_PROTOBUFC=0 \|
> |-DWITH_PYTHON=OFF \|
> |-DWITH_SVGCAIRO=OFF \|
>   When I use Mapserver 7.6.4 in the same setup, the following lines appear:
> -- /usr/include/php/20200930/main
> -- Found PHP-Version 8.0.21 (using /usr/bin/php-config)
> In Mapserver 8 these are missing and accordingly the output in
> mapscripts is:
> --* Mapscripts
> --* Python: disabled
> --* PHPNG: disabled
> That means PHP is not activated. In comparison the output with Mapserver
> 7.6.4:
> --* Mapscripts
> --* PHP: ENABLED
> --* PHPNG: disabled
> It is the same server with the same installation components.
> Accordingly, in a make and make under Version 8 install PHP Mapscript is
> not installed.
> php - v generates the following
> Unable to load dynamic library 'php_mapscript.so' (tried:
> /usr/lib/php/20200930/php_mapscript.so
> (/usr/lib/php/20200930/php_mapscript.so: cannot open shared object file:
> No such file or directory), /usr/lib/php/20200930/php_mapscript.so.so
> (/usr/lib/php/20200930/php_mapscript.so.so: cannot open shared object
> file: No such file or directory)) in Unknown on line 0
> Note: PHP is installed with FPM module (php8.0-fpm) and instead of
> mpm_prefork mpm_event is used.
> Any idea?
> Thanks Sven
More information about the MapServer-users mailing list
