[mapserver-users] Mapserver projection, auto and extent
Trygve Aspenes trygve at aspenes.priv.no
Thu May 19 06:26:25 PDT 2022
Hi
I got a geotiff raster with a projection which is not an EPSG code, so
in the mapfile I use AUTO in the layer projection. This also means I
skip the extent and projection in map level in the mapfile. In one
client this works fine ( this client request epsg:3857 and this looks
fine to me)
But in QGIS, this does not work nor any other projections.
Then I add EXTENT and PROJECTION in my mapfile like this:
MAP
   EXTENT -56.6378419 31.5007307 95.025531 84.6828537
   PROJECTION
     "init=epsg:4326"
   END
END
And then EPSG:4326 works in QGIS also. But if I try to change the
projection i qgis, eg to EPSG:3857, this does not work in QGIS, even if
it still work in my other client.
So what is it that I don't understand about EXTENT and PROJECTION. I
have looked at the documentation
https://mapserver.org/mapfile/projection.html#important-notes and and as
far as I can understand from the second bullet point the projection
definition at map level can be looked as the outgoing projection with
the extent accordingly.
What do I need to do to make QGIS be able to use other projections as
well?
I do have a link to my getcapabilities document, but hesitates to put it
here.
Trygve Aspenes
More information about the MapServer-users mailing list
