[MapServer-users] using SCALETOKEN in an EXPRESSION
Eichner, Andreas - SID
Andreas.Eichner at sid.sachsen.de
Thu Nov 10 00:29:25 PST 2022
According to RFC 86 SCALETOKENs are used to replace tokens inside a layer’s DATA statement - so it might simply not work within class expressions.
As a workaround you might use MINSCALEDENOM and MAXSCALEDENOM within CLASS.
Kind regards,
Andreas
-----Ursprüngliche Nachricht-----
Von: MapServer-users <mapserver-users-bounces at lists.osgeo.org> Im Auftrag von Richard Greenwood
Gesendet: Donnerstag, 10. November 2022 03:00
An: mapserver <mapserver-users at lists.osgeo.org>
Betreff: [MapServer-users] using SCALETOKEN in an EXPRESSION
Can anyone tell me what's wrong with my EXPRESSION below? I'm trying to filter features from the National Hydrology Dataset based on scale using SCALETOKEN and I can't seem to get it right. [Visibility] is a field in the data that suggests the scale at which a feature should be shown.
Thanks!
LAYER
NAME "flowline"
TYPE line
DATA "shapefiles3857/nhd/flowline"
SCALETOKEN
NAME "%priority%"
VALUES
"0" "0"
"24000" "24000"
"50000" "50000"
"100000" "100000"
"250000" "250000"
"500000" "500000"
"1000000" "1000000"
"2000000" "2000000"
"5000000" "5000000"
END
END
CLASS
EXPRESSION ([Visibility] > %priority%)
STYLE
COLOR 158 196 255
MINSIZE 1
SIZE 3
MAXSIZE 6
END
END
END
Richard W. Greenwood
www.greenwoodmap.com <http://www.greenwoodmap.com>
Type: application/x-pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20221110/484d4d58/attachment.bin>
More information about the MapServer-users
