[MapServer-users] using SCALETOKEN in an EXPRESSION
Richard Greenwood
richard.greenwood at gmail.com
Thu Nov 10 04:34:43 PST 2022
Ah, good point. The examples do all show it being used in conjunction with
the DATA statement.
Thanks,
Rich
On Thu, Nov 10, 2022 at 1:29 AM Eichner, Andreas - SID <
Andreas.Eichner at sid.sachsen.de> wrote:
> According to RFC 86 SCALETOKENs are used to replace tokens inside a
> layer’s DATA statement - so it might simply not work within class
> expressions.
> As a workaround you might use MINSCALEDENOM and MAXSCALEDENOM within CLASS.
> Kind regards,
> Andreas
> -----Ursprüngliche Nachricht-----
> Von: MapServer-users <mapserver-users-bounces at lists.osgeo.org> Im Auftrag
> von Richard Greenwood
> Gesendet: Donnerstag, 10. November 2022 03:00
> An: mapserver <mapserver-users at lists.osgeo.org>
> Betreff: [MapServer-users] using SCALETOKEN in an EXPRESSION
> Can anyone tell me what's wrong with my EXPRESSION below? I'm trying to
> filter features from the National Hydrology Dataset based on scale using
> SCALETOKEN and I can't seem to get it right. [Visibility] is a field in the
> data that suggests the scale at which a feature should be shown.
> Thanks!
> LAYER
> NAME "flowline"
> TYPE line
> DATA "shapefiles3857/nhd/flowline"
> SCALETOKEN
> NAME "%priority%"
> VALUES
> "0" "0"
> "24000" "24000"
> "50000" "50000"
> "100000" "100000"
> "250000" "250000"
> "500000" "500000"
> "1000000" "1000000"
> "2000000" "2000000"
> "5000000" "5000000"
> END
> END
> CLASS
> EXPRESSION ([Visibility] > %priority%)
> STYLE
> COLOR 158 196 255
> MINSIZE 1
> SIZE 3
> MAXSIZE 6
> END
> END
> END
> Richard W. Greenwood
> www.greenwoodmap.com <http://www.greenwoodmap.com>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20221110/3566dca9/attachment.htm>
More information about the MapServer-users
