[MapServer-users] "Emergency" map server on Raspberry Pi - raster/PNG source in folder structure
Stefan Gofferje lists at home.gofferje.net
Wed Oct 12 08:57:35 PDT 2022
On 10/12/22 16:37, Sven Schroeter wrote:
> I don't know if I understood you correctly, but I think the solution for
> you would be an image catalog, right?
> Then you would have only one layer for the UTM maps.
> In the mapfile it would look like this, in the .dbf in the column
> "location" would be the paths to the png data.
> LAYER
>      NAME "utm_data"
>      STATUS ON
>      MAXSCALE 8000
>      TILEINDEX "filesindex_png.shp"
>      TILEITEM "location"
>      TYPE RASTER
>      PROCESSING "Resample=average"
>      CLASS
>      name "utm_data"
>      END
> END
Like here:
https://mapserver.org/input/raster.html#rasters-and-tile-indexing ?
I'm still a total newbie to mapserver and haven't had much time to
tinker with it yet, unfortunately. But that looks easy enough.
So, basically, I 'find' all pngs/pgws, move them from the subfolders
into one folder and run gdaltindex over the folder. And that creates a
shapefile which I use as data source? Let's try that.
-S
  (o_   Stefan Gofferje            | SCLT, MCP, CCSA
  //\   Reg'd Linux User #247167   | VCP #2263
  V_/_  https://www.gofferje.net   | https://www.saakeskus.fi
More information about the MapServer-users mailing list
