[MapServer-users] Mapserver reverse proxy
Marcin Niemyjski mniemyjski at cloudferro.com
Thu Oct 27 02:52:30 PDT 2022
Hello,
coming back to you with another question - continuation of my issue about keeping mapfiles on s3 while using docker. I managed to create a reverse proxy which redirects to the s3 bucket (by editing apache .conf file) and it works. The problem is: when i try to use it on wms resource url in form:
https://www.lpis.pl/cgi-bin/mapserv?map=/martest/jrc.ma (/martest is a proxy pass which I use) the part after ?map= is operated by mapserver and reverse proxy doesn't work so I get error:  msLoadMap(): Unable to access file. (/martest/jrc.map) is there any workaround?
As always thank you,
Marcin
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20221027/fb1b6c10/attachment.htm>
More information about the MapServer-users mailing list
