[MapServer-users] MapServer-users Digest, Vol 176, Issue 14
    Boubacar Bah
    bahbouba.909 at gmail.com
    Sun Sep 25 05:02:17 PDT 2022
hi  van den Broecke  , even by making this correction the transaction is
not carried out towards the database
Le dim. 25 sept. 2022 à 12:28, <mapserver-users-request at lists.osgeo.org> a
écrit :
> Send MapServer-users mailing list submissions to
>         mapserver-users at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>         https://lists.osgeo.org/mailman/listinfo/mapserver-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         mapserver-users-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of MapServer-users digest..."
> Today's Topics:
>    1. Re: asking help (Just van den Broecke)
> Message: 1
> Date: Sun, 25 Sep 2022 01:35:04 +0200
> From: Just van den Broecke <justb4 at gmail.com>
> To: mapserver-users at lists.osgeo.org
> Subject: Re: [MapServer-users] asking help
> Message-ID:
>         <CAC8+mc2pMuvpgNg=Y=
> 9hyQJ9gq6CFcThKWegi4g8cAbC3ZhecA at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> switch(mode) {
>                 case 'insert':
>                     mode = formatWFS.writeTransaction([f], null, null,
> formatGML);
>                     break;
>                 case 'update':
>                     node = formatWFS.writeTransaction(null, [f], null,
> formatGML);
> First case: 'mode =' should be 'node ='
> On Sun, Sep 25, 2022, 00:26 Boubacar Bah <bahbouba.909 at gmail.com> wrote:
> > hello, i need your help regarding tinyows wfs transaction.
> > by the way I put in an online editing application.
> > in which I used the wfs transaction to send the request to my postgis
> > database.
> > but the problem is that if I edit an entity in the application the
> > transaction does not run to my database.
> > So I don't know where the problem is in my code.
> > Any help will be welcome.
> > Below is the code for the program in question:
> > <!DOCTYPE html>
> > <html>
> >     <head>
> >         <title>WFS - GetFeature</title>
> >         <meta charset="utf-8"/>
> >         <link rel="stylesheet" href="
> https://cdn.jsdelivr.net/gh/openlayers/openlayers.github.io@master/en/v6.15.1/css/ol.css
> > " type="text/css">
> >         <style>
> >           .map {
> >             height: 400px;
> >             width: 100%;
> >         </style>
> >         <script src="
> https://cdn.jsdelivr.net/gh/openlayers/openlayers.github.io@master/en/v6.15.1/build/ol.js
> > "></script>
> >     </head>
> >     <body>
> >         <div id="map" class="map"></div>
> >         <label >Modifier  </label>
> >         <button name="modifier" id="mod" value="Edit"></button>
> >         <label >Creer  </label>
> >         <button name="Creer" id="creer" value="creer"></button>
> >         <label >Stop Edition  </label>
> >         <button name="stop_modif" id="stop_mod"
> value="stop_Edit"></button
> >         <script>
> >           var draw, modify, snap;
> >           var maprojection= new ol.proj.Projection({
> >             code:'EPSG:4326',
> >             extent:[-20,30,20,50],
> >             units:'degrees',
> >             axisOrientation:'enu'
> >           //surcharge de la projection EPSG:4326
> >           ol.proj.addEquivalentProjections([ol.proj.get('EPSG:4326'),
> > maprojection]);
> >           var wfsSource = new ol.source.Vector({
> >             format: new ol.format.GeoJSON(),
> >             url: function(extent) {
> >                 return '
> http://127.0.0.1/cgi-bin/tinyows.exe?service=WFS&'
> > 'version=1.1.0&request=GetFeature&typename=tows:demo_tyny&'+
> >                 'outputFormat=application/json&srsname=EPSG:4326&'+
> >                 'bbox='+ extent.join(',')+',EPSG:4326';
> >             strategy: ol.loadingstrategy.bbox,
> >             projection: maprojection
> >           var vector = new ol.layer.Vector({
> >             source: wfsSource,
> >             style: new ol.style.Style({
> >                 stroke: new ol.style.Stroke({
> >                     color: 'rgba(0,0,255,1.0)',
> >                     width:4
> >           var map = new ol.Map({
> >             layers:[vector],
> >             target: document.getElementById('map'),
> >             view: new ol.View({
> >                 projection: maprojection,
> >                 center: [2.5,46],
> >                 maxZoom: 20,
> >                 zoom: 1
> >           var etat_edition= document.getElementById('mod');
> >           var etat_creation= document.getElementById('creer');
> >           var stop_edition= document.getElementById('stop_mod');
> >           var draw, snap, modify; //declarees globalement pour les
> > activers ou non a la guise
> >           var formatWFS = new ol.format.WFS();
> >           var xs = new XMLSerializer();
> >           var formatGML =  new ol.format.GML3({
> >             version:'1.1.0',
> >             featureNS: 'http://www.mapserver.org/tinyows',
> >             url: 'http://127.0.0.1/cgi-bin/tinyows.exe',
> >             featureType:'demo_tyny',
> >             srsName:'EPSG:4326',
> >             geometryName: 'geom',
> >             SchemaLocation:'
> http://127.0.0.1/cgi-bin/tinyows.exe?service=wfs&request=DescribeFeatureType&version=1.1.0&typename=tows:demo_tyny
> >           var transactWFS = function (mode, f) {
> >             var node;
> >             switch(mode) {
> >                 case 'insert':
> > formatGML);
> >                     break;
> >                 case 'update':
> > formatGML);
> >                     break;
> >                 case 'delete':
> >                     node = formatWFS.writeTransaction(null, null, [f],
> > formatGML);
> >                     break;
> >             var xml_data = xs.serializeToString(node);
> >             fetch('http://localhost/cgi-bin/tinyows.exe?service=wfs', {
> >                 method:'POST',
> >                 body: xml_data
> >             }).then(function() {
> >                 wfsSource.clear();
> >           function add_snap() {
> >             snap = new ol.interaction.Snap({source: vector.getSource()});
> >             map.addInteraction(snap);
> >           function add_modify(){
> >             stopInteractions();
> >             add_snap();
> >             modify = new ol.interaction.Modify({source: vector.getSource
> >             map.addInteraction(modify)
> >           function add_creer(){
> >             stopInteractions();
> >             add_snap();
> >             draw = new ol.interaction.Draw({
> >                 source: vector.getSource(),
> >                 type:"MultiPolygon",
> >                 geometryName:'geom'
> >             draw.on('drawend', function(e){
> >                 code_saisi=prompt("code_commune");
> >                 e.feature.setProperties({'code_commune':code_saisi});
> >                 transactWFS('insert',e.feature);
> >             map.addInteraction(draw);
> >           function stopInteractions() {
> >             map.removeInteraction(draw);
> >             map.removeInteraction(snap);
> >             map.removeInteraction(modify)
> >           etat_edition.onclick = function() {
> >             add_modify();
> >           etat_creation.onclick = function() {
> >             add_creer();
> >           stop_edition.onclick = function () {
> >             stopInteractions();
> >         </script>
> >     </body>
> > </html>
> > MapServer-users at lists.osgeo.org
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.osgeo.org/pipermail/mapserver-users/attachments/20220925/2869323d/attachment.htm
> Subject: Digest Footer
> End of MapServer-users Digest, Vol 176, Issue 14
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20220925/da4ffb39/attachment.htm>
More information about the MapServer-users
