[MapServer-users] Swig Mapscript Still Fails to Build with PHP 8
b g mapserverlearn at outlook.com
Tue Sep 27 08:39:00 PDT 2022
Good morning,
I have been trying to build the MapServer 8.0 release using PHP 8. I am a new user having only been working with MapServer for just a couple of months, please forgive me I don't ask questions in the appropriate way.
I have seen posts on the Github referring to the new release as supporting PHP 8 as mentioned here: https://github.com/MapServer/MapServer/pull/6430 and here: https://github.com/MapServer/MapServer/issues/6632. However, I fail to see a post mentioning the steps of what I need to change in the build process. My process is as follows: I install Homebrew and then install the dependencies -- httpd php at 8.0 cmake pkg-config swig fcgi gd gdal geos giflib postgresql proj protobuf-c proj at 7. After this I clone MapServer from Github and checkout rel-8-0-0. Next, I run cmake with the following options:
cmake ..  -DCMAKE_BUILD_TYPE=RELEASE -DCMAKE_FIND_FRAMEWORK=LAST -DCMAKE_VERBOSE_MAKEFILE=ON -Wno-dev -DWITH_CLIENT_WFS=ON -DWITH_CLIENT_WMS=ON -DWITH_CURL=ON -DWITH_FCGI=ON -DWITH_FRIBIDI=OFF -DWITH_GDAL=ON -DWITH_GEOS=ON -DWITH_HARFBUZZ=OFF -DWITH_KML=ON -DWITH_OGR=ON -DWITH_POSTGIS=ON -DWITH_PROJ=ON -DWITH_PYTHON=OFF -DWITH_SOS=ON -DWITH_WFS=ON -WITH_CAIRO=ON -DCMAKE_SKIP_RPATH=ON -DWITH_PHPNG=ON -DCMAKE_INCLUDE_PATH="/usr/local/Cellar/postgresql"
And then make. However, make fails with errors referring to bindings needing PHP 7. The error log is listed below:
https://pastebin.com/99xWFcpE
Clearly, I must be missing something or doing something wrong during the build process since others have stated that version 8.0.0 works with PHP 8. Could anyone be so kind to point out my error so that I could get this to work? Any help is much appreciated. Thank you so much.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20220927/b9495d7e/attachment.htm>
More information about the MapServer-users mailing list
