[MapServer-users] WMS: Not all features show, depending on how I zoom and pan
Antonis Christofides
antonis at antonischristofides.com
Wed Sep 28 04:03:18 PDT 2022
Hello,
I have a problem that has already been discussed in stackexchange
(https://gis.stackexchange.com/questions/440902/mapserver-wms-not-all-features-show-depending-on-how-i-zoom-and-pan),
but without solution so far.
I'm repeating the full text here, but if there's any problem with the images it
might be better to go to stackexchange to read it.
Here is how QGIS shows an irrigation network, received by MapServer via WMS and
superimposed on OpenStreetMap:
enter image description here
Here is the same thing, but slightly panned to the right:
Several items are obviously missing. In fact there are items missing in the top
picture as well. Different items become visible as I zoom and pan differently.
Since this pretty much tells the whole story, I'm not going into more details.
MapServer version is 7.6.2 (prepackaged for Debian). The base URL is
https://poros.irmasys.com/cgi-bin/mapserv?map=/opt/aira-poros/aira-poros/mapserver/extralayers.map.
Finally, below I paste the interesting parts of the mapfile.
Thanks!
Antonis
|MAP NAME "aira-poros" STATUS ON SIZE 9040 7731 EXTENT 103986.57 3850796.18
1007945.14 4623933.00 UNITS meters PROJECTION "init=epsg:2100" END CONFIG
MS_ERRORFILE "/var/log/mapserver/extralayers.log" # [Omitting some OUTPUTFORMAT
sections] WEB IMAGEPATH "/var/cache/mapserver/" IMAGEURL "/mapserver_tmp/"
METADATA "wms_title" "Aira Poros" "wms_onlineresource"
"https://poros.irmasys.com/cgi-bin/mapserv?map=/opt/aira-poros/aira-poros/mapserver/extralayers.map&"
"wms_srs" "EPSG:4326 EPSG:2100 EPSG:3857" "wms_enable_request" "*"
"wms_feature_info_mime_type" "text/html" "wfs_title" "Aira Poros"
"wfs_onlineresource"
"wfs_srs" "EPSG:2100 EPSG:4326 EPSG:3857" "wfs_enable_request" "*" END END LAYER
NAME "irrigation-network" TYPE LINE CONNECTIONTYPE OGR CONNECTION
"irrigation-network.gml" METADATA "wms_title" "Irrigation network" "wfs_title"
"Irrigation network" "gml_include_items" "all" "gml_featureid" "id" END STATUS
ON PROJECTION "init=epsg:2100" END CLASSITEM 'category' CLASS EXPRESSION '1'
STYLE COLOR 0 0 255 OPACITY 50 WIDTH 6 END LABEL COLOR 0 0 255 ANGLE FOLLOW
OFFSET 5 99 MAXSCALEDENOM 10000 TEXT "[irri_code]" END LABEL COLOR 0 0 255 ANGLE
FOLLOW OFFSET -8 99 MAXSCALEDENOM 10000 EXPRESSION (NOT('[Diameter]' = '')) TEXT
"D=[Diameter] mm" END END # [Omitting three more classes] END # [Omitting four
more layers] END|
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20220928/6a9e3911/attachment.htm>
More information about the MapServer-users
