[MapServer-users] Swig Mapscript Still Fails to Build with PHP 8
Seth G sethg at geographika.co.uk
Tue Sep 27 10:31:17 PDT 2022
The CI setup for MapServer doesn't test Homebrew/Mac, so that could be one possible issue.
MapServer 8 and PHP 8 however is tested on Linux - see https://github.com/MapServer/MapServer/blob/main/.travis.yml and the most recent log for PHP 8 - https://app.travis-ci.com/github/MapServer/MapServer/jobs/583600218
Lots of the install logic run on Travis is contained in https://github.com/MapServer/MapServer/blob/main/ci/travis/before_install.sh
Check for differences with your own logs to see what might be causing the errors.
Good luck!
Seth
web:https://geographika.net
twitter: @geographika
On Tue, Sep 27, 2022, at 5:39 PM, b g wrote:
> Good morning,
> I have been trying to build the MapServer 8.0 release using PHP 8. I am a new user having only been working with MapServer for just a couple of months, please forgive me I don't ask questions in the appropriate way.
> I have seen posts on the Github referring to the new release as supporting PHP 8 as mentioned here: https://github.com/MapServer/MapServer/pull/6430* *and here: https://github.com/MapServer/MapServer/issues/6632. However, I fail to see a post mentioning the steps of what I need to change in the build process. My process is as follows: I install Homebrew and then install the dependencies -- httpd php at 8.0 cmake pkg-config swig fcgi gd gdal geos giflib postgresql proj protobuf-c proj at 7. After this I clone MapServer from Github and checkout rel-8-0-0. Next, I run cmake with the following options:
> cmake ..  -DCMAKE_BUILD_TYPE=RELEASE -DCMAKE_FIND_FRAMEWORK=LAST -DCMAKE_VERBOSE_MAKEFILE=ON -Wno-dev -DWITH_CLIENT_WFS=ON -DWITH_CLIENT_WMS=ON -DWITH_CURL=ON -DWITH_FCGI=ON -DWITH_FRIBIDI=OFF -DWITH_GDAL=ON -DWITH_GEOS=ON -DWITH_HARFBUZZ=OFF -DWITH_KML=ON -DWITH_OGR=ON -DWITH_POSTGIS=ON -DWITH_PROJ=ON -DWITH_PYTHON=OFF -DWITH_SOS=ON -DWITH_WFS=ON -WITH_CAIRO=ON -DCMAKE_SKIP_RPATH=ON -DWITH_PHPNG=ON -DCMAKE_INCLUDE_PATH="/usr/local/Cellar/postgresql"
> And then make. However, make fails with errors referring to bindings needing PHP 7. The error log is listed below:
> https://pastebin.com/99xWFcpE
> Clearly, I must be missing something or doing something wrong during the build process since others have stated that version 8.0.0 works with PHP 8. Could anyone be so kind to point out my error so that I could get this to work? Any help is much appreciated. Thank you so much.
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20220927/028e65d5/attachment.htm>
More information about the MapServer-users mailing list
