[MapServer-users] Multi language worldmap (basemaps)
thomas bonfort thomas.bonfort at gmail.com
Fri Apr 14 01:37:31 PDT 2023
Hi Richard,
I don't have much more help to provide you other than saying you are on the
right track.
uni fonts/unifont_sample.ttf
> unib fonts/unifont_sample.ttf
you are referencing the same font file under 2 different names. I don't
think that is the root cause of your issue, but this is definitely useless
> And using
> FONT "sc,noto,uni,tw"   # does order matter?
Yes the order does matter, any codepoint will be loaded from the first font
(from left to right) that contains it
> AH01215: Unable to load glyph 62314 for font "uni". Using ? as fallback.:
> /usr/lib/cgi-bin/mapserv
> [Fri Apr 14 10:12:20.644638 2023] [cgi:error] [pid 141599] [client
> ::1:46140] AH01215: msGetGlyphByIndex(): General error message. unable to
> load glyph 62314 for font "uni": /usr/lib/cgi-bin/mapserv
> while my script tells me 'glyph 62314' is in 'fonts/unifont_sample.ttf'...
you'll have to dig in more as to why this is happening, from what I
understand you are specifying the fonts correctly and that glyph /should/
be found, but the error message is explicitly telling you this is not the
case.
regards,
TB
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20230414/351f1511/attachment.htm>
More information about the MapServer-users mailing list
