[MapServer-users] multiple shapepaths
Jan Hartmann j.l.h.hartmann at gmail.com
Sat Dec 2 10:32:19 PST 2023
Yes, that is what I sought, didn't know it was possible. Thanks!
Jan
On 02/12/2023 19:29, Steve Lime wrote:
> One other thought, you can use multiple paths via runtime subs to
> approximate what I think you’re looking for, so:
> WEB
>   VALIDATION
>     path1_default “/opt/path1”
>     path1 “^\/opt\/path1$”
>   path2_default “/opt/path2”
>   path2 “^\/opt\/path2$”
>   END
> END
> Then in DATA values you’d use %path1% or %path2%. This is another use
> case for variables that was suggested recently. We could, perhaps,
> define a way to mark something as immutable via url so the regex could
> be simplified and only the default would ever be used (e.g. “path2”
> “immutable”).
> —Steve
> On Fri, Dec 1, 2023 at 11:28 PM Steve Lime <sdlime at gmail.com> wrote:
>     Nope, just the one value.
>     On Fri, Dec 1, 2023 at 1:02 PM Jan Hartmann via MapServer-users
>     <mapserver-users at lists.osgeo.org> wrote:
>         Hi,
>         Is it possible to use multiple paths in a shapepath?
>         ./data1:./data2
>         does not work
>         Jan
>         _______________________________________________
>         MapServer-users mailing list
>         MapServer-users at lists.osgeo.org
>         https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20231202/c96b5549/attachment.htm>
More information about the MapServer-users mailing list
